foam for our seats
Old Sep 29, 2004 | 10:19 PM
radiateu2's Avatar
foam for our seats
I have a 1987 camaro I wouldlike to replace the foam for the drivers seat...does anyone know of a place that can do this? Or possibly know of a kit I could do this myself
Old Sep 30, 2004 | 09:07 AM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
How bad is your foam?
You can reuild it, I did mine and they were REALLY rough.!!
I had everything from small chunks out of the cushion. to holes blown out the side panels from the support cables.
THey look like new now with the new covers, couldn't be happier.
Old Sep 30, 2004 | 09:39 AM
radiateu2's Avatar
what did you useto rebuild them though
Old Sep 30, 2004 | 11:47 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
Well, that's why I asked how bad they were...
Any dense foam will work...I used carpet padding, YES, CARPET PADDING!!!
Not the stuff that's made up of all different kinds and colors, go to a local carpet dealer, and see if they got any scraps, good quality dense closed core foam. Mine was white. They'll probably give them to you.
I got about a 3x3 chunk for mine and had quite a bit left over, My guy only charged me six bucks!!!
After I repaired all the cabling and wires that were sticking out... I glued the existing foam tears together, Use 3m super77 spray adhesive... light coats on each surface of the pieces to be glued.
Let tack, and mash them together, they will become as one!!!!
I'm tellin' ya it will tear in a completley different spot before this repair will let go!!!
You will use the same process to fill any large chunks that are missing with your "new" foam. cover the patches with another piece , just approximate the size with a utility knife.
When everything's dry you shape it with a grinder, Preferrably a high speed air grinder. (Small 90 degree angle grinder will work great.)
Don't do it in your house, cause it makes a huge mess!!!!
looks like a pro job and very durable!!!!!!
Old Sep 30, 2004 | 12:56 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
u can add extra foam to your bolsters to give them a tighter squeeze around your waist, my friend did that and it looked and worked great.
Old Sep 30, 2004 | 01:58 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
yep, I did the same before i assembled the new covers
Old Nov 16, 2010 | 08:30 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Re: foam for our seats
Just saving info
Old Nov 16, 2010 | 09:52 PM
Camaroboi's Avatar
Car: '84 Berlinetta, '86 Z28
Engine: 2bbc 2.8, MPTI 5.0
Transmission: 5spd manual, 4 spd auto
You can also go to Walmart or any craft store and get a 2'X2'X4". It depends on the type you get for the price. At walmart I think it was around $8 for the flame retardant one, and it is dense too
Old Nov 16, 2010 | 11:09 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Found some on Ebay here is the link:http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I am in need of some of these too, but haven't found the $$$ in the budget yet to buy some.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
