Need help, BAD
Old Nov 16, 2010 | 07:52 PM
Camaroboi's Avatar
Car: '84 Berlinetta, '86 Z28
Engine: 2bbc 2.8, MPTI 5.0
Transmission: 5spd manual, 4 spd auto
Need help, BAD
I am working on my 1984 Camaro Berlinetta right now. I know it has nothing towards the Z car, but that is where these ideas play off. My step dad and I were going to get it running this year, he died last. I ended up just off a whim getting a new EIM chip, because the crank was so strong, and she ran for the first time in 4 years. Through the course I have been checking the posts, finding a way to really say I got a camaro, instead of "ehh, it's a berlinetta". I found the concept parts I want for the body. This is where it starts....
I started stripping the paint because areas were chipped or bubbling. I got almost the whole rear done, except the lower quarter panels. I'm getting a stronger grinding pad/wheel tomorrow. I was wondering, that after setting a primer coat, should I also set a layer of resin(bondo) to protect the hard work?
Attached Thumbnails Need help, BAD-sniper-skirt.jpg   Need help, BAD-dsc00140.jpg
Old Nov 16, 2010 | 11:17 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Need help, BAD
No you need to strip it to the metal then apply 1-2 coats of epoxy primer
Old Nov 16, 2010 | 11:47 PM
Camaroboi's Avatar
Re: Need help, BAD
Thanks for a quick response. I'm glad I only put a light coat of primer down, just to protect the bare metal. Does there happen to be an applicator that can help remove rust from the pits or should I just grind out the rust and patch?
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
