Rear Hatch Won't Shut
Old Feb 23, 2010 | 12:56 PM
deano17's Avatar
I just bought an 89 camaro RS and the hatch won't shut. I don't think its an electronic pull down but I could be wrong. It was locked and I turned the key and unlocked it but when i pushed it back down to close it, it the latch wouldn't engage. I took a key and pushed the latch down with it and it clicked into place then i turned the key and it unlocked but it won't engage when the hatch is pushed down. Anyone have any ideas?
Old Feb 23, 2010 | 01:45 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Rear Hatch Won't Shut
I would first check your accessory fuse under the dash, if you haven't already.
Old Feb 24, 2010 | 10:32 PM
Brad5117's Avatar
if it is a pull down wat i did with mine is weld it shut and disconnect the motor but it will still open with ke just hold it where the hatch fits flush and weld it , if it is not a pull down just take off ur plastic and unbolt the two bolts and u can slide it up untill it hits
Old Feb 24, 2010 | 11:07 PM
deano17's Avatar
i'm pretty sure it's a slam shut. i'm thinking just after years of slamming, the latch has moved down. when the weather is nicer i'll go take a look and try and move it back up and see if that works. thanks for the input!
Old Feb 24, 2010 | 11:11 PM
Brad5117's Avatar
np man if it still is moved down from slamming it i would just weld it , then u dont have to worry about it anymore
Old Feb 27, 2010 | 02:25 AM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
You mean weld the sliders? Took me all of a day getting the parts together to rebuild the pull-down motor. Not a tough job.
Old Feb 28, 2010 | 09:01 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
One other thing, if its electronic close, the trans has to be in park or neutral if its auto trans.
Old Mar 1, 2010 | 05:50 PM
deano17's Avatar
Alright so i finally go around to checking out the latch. it was originally a pull down because i see all the wires for it hanging loose. it was converted to a slam shut. there are 3 bolts that connect the latch assembly to the trunk. one on the bottom and one on each side. there are 2 rails which seem like they should slide on each side but they have been welded in 2 places on each side. i assume that was done by the person who installed the slam latch.
at the time i checked it out i didn't have any tools because it isn't at my house. do you think i could loosen up the three bolts and maybe there'd be enough play to move it up enough for the lock to engage? or do i need to get a new latch assembly?
Old Mar 1, 2010 | 06:56 PM
AmorgetRS's Avatar
You should be able to move it up a little bit.
I hate it when people weld/screw the pull down motor...
Old Mar 1, 2010 | 10:12 PM
Zerocyde's Avatar
Car: 88 Camaro
Axle/Gears: 4.11
Agreed. Though I'll take screw over weld. At least I was able to take the screws out and easily rebuild the assembly.
Old Nov 17, 2010 | 08:34 PM
proj88formula's Avatar
Car: formula
Engine: 305 tbi
Axle/Gears: Ls1 3:42
hey does anybody know where i can buy a rear hatch pull down mechanism. someone welded mine and in doing so now my hatch doesnt seal all the way in a car wash. i can seem to find them any where. and is there a better place to get parts for a 88 formula then classic industries? they just dont have much for third gens. thanks for the info. james
Old Nov 17, 2010 | 08:51 PM
AmorgetRS's Avatar
If you are willing to spend the $$, buy one from www.top-downsolutions.com. It will be the last hatch pull down you need to buy.
If not, watch the classifieds.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
