CompCams XE256H
Old Oct 14, 2004 | 09:12 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
LB9 Cam discusion *comp xe256h*
Well, I was concidering the compucam 2040 http://www.cranecams.com/?show=brows...Type=camshaft, but this Xtreme Energy CompCam (XE256H) looks 1000 times better.http://www.compcams.com/Technical/Cu...ML/128-169.asp The only question is, do I go with the 110 lsa or the 112 lsa version? I really dont mind some chop in the idle, and it seems that the 110 would make better power. Also keep in I plan on upgrading to the 89' ecm and getting into prom tunning. I dont think springs an guide clearence will be a problem as I plan getting the Manley spring and retainer combo mentioned here-------> https://www.thirdgen.org/techbb2/sho...manley+springs
and these 1.6 rockers ----->http://www.sdpc2000.com/catalog/1956...86-Earlier.htm
Opinions welcome and personal experiences are welcome and apreciated
Old Oct 14, 2004 | 12:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would get the EFI friendly grind, aka the 112 LSA. EFI doesn't seem to be able to tolerate intake reversion like carbs can so the intake valve event was bumped up a bit. The overlap helps on the amount of fuel that goes right through (hydrocarbons).
I would get a set of the Comp Magnum 1.52 ratio rockers. With the set that you show, they would bring the exhaust side to about .486" which is a tad much on the factory heads. Now, if you get the .050" retainers, then that's a slightly different story. But I wouldn't run the stampled steel anyways. They're basically the factory boat-like rubber pieces but in an increased ratio. Get the Magnum roller tips.
I run the 256h cam (110 LSA version) in my LG4 with 1.52 Magnum roller tips. I use Isky 235-D valve springs (much like the Manley's) and their recommended retainers. Those are on on 416 heads.
Old Oct 14, 2004 | 01:20 PM
Ok, so one no on the 110 lsa. Anybody else? Anybody use a 110 lsa cam in an EFI car?
Old Oct 14, 2004 | 02:24 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I keep hearing to stay above 110 LSA for vacuume reasons
Old Oct 14, 2004 | 03:02 PM
In this post https://www.thirdgen.org/techbb2/sho...hlight=110+lsa TRAXION seems to think it's easy to get a 110 lsa cam to work with TPI. I don't know myself, I'm just trying to wiegh all my options, and if I can get away with 110 lsa I will.
Old Oct 14, 2004 | 05:37 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
what heads r u using?
Old Oct 14, 2004 | 05:58 PM
i will be using stock 85' (perimeter bolt) LB9 heads with the manley spring and retainer combo mentioned above. Also keep in mind the particular cam I want to use is considerably smaller cam than the ones mentioned in the thread mentioned above.
Old Oct 16, 2004 | 12:17 AM
Mark 89Formula's Avatar
That's the key. Lobe seperation angle by itself means little. Combine LSA with the seat duration and you establish the overlap period which is critical to idle vacuum, idle stability, computer compatibility (all the same thing).
Take a look at the cam GM put in it's Ramjet crate EFI engine. It's ground on a 109 deg LSA but is short duration so not a lot of overlap.
Valve overlap at .006" for the XE256H is 38 degs on a 112 deg LSA and 42 degs on a 110 deg LSA. For comparison, 2 cams commonly used in EFI engines have the following overlap at .006": ZZ3/4 cam - 44 degs, ZZ9 - 48 degs. Both values were determined by measuring each cam on a Cam Pro Plus machine. Conclusion: you can run 110 deg LSA on that Comp cam and still be EFI friendly.
Old Oct 16, 2004 | 01:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
3 words: Intake closing point.
Old Oct 16, 2004 | 02:03 AM
elaborate please, im still in the process of learning this stuff.
Old Oct 17, 2004 | 04:42 PM
I think Im pretty much set on the 112lsa version now unless sombody convices me otherwise. Im also probably going to get so better quality rockers. either full rollers or roller tip, as long as they can fit under the stock 85' perimeter valve covers. Is there any reason NOT to get the largest ratio rocker possible from a performance stand point? Can more lift ever be bad? (excluding physical limitations of the valvetrain) I guess what I am trying to say is.... as long as the heads can handle it, does it or does it not make sense to always opt for the larger ratio? any input is welcome.
Old Oct 17, 2004 | 07:05 PM
1320 Right Ln.'s Avatar
I just noticed this little detail, but isn't the crane cam a Hydraulic roller, while that comp XE256H is a hydraulic flat tappet? completely different style.
Old Oct 17, 2004 | 07:51 PM
neither cam i mentioned was a roller. my lb9 is not a roller block. Crane makes the 2040 in both rolloer and non-roller versions. It really is unimportant now as I found this particular comp cam, It completely smokes the crane 2040
Old Oct 18, 2004 | 04:23 PM
ttt
Old Oct 20, 2004 | 09:42 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
i will be running an xe292 grind in my lt1 intaked 355.... with tfs heads.... dont know how its gonna go yet but will keep yall up on the info as i get it motor will not be ready will after christmas though.....
ChaseDale3and8
Sep 1, 2015 01:49 PM
RacingGreenSC
Aftermarket Product Review
Nov 14, 2001 05:00 PM
Dirtybird355
Aug 25, 2001 05:15 PM
