Anyone have 1 7/8 or 2" headman long tubes
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
2" primaries? You sure thats not for a big block? Thats too big to fit onto a small block head.
Link to Stahl
http://www.stahlheaders.com/Frame%20New%20Drag.htm
Click on part number 108
Jerry
Car: 87 T/A
Those are valid numbers. I had the same question, seems like it'd be tough to fit in there. But that's what is called out. They're like $500+, but for 2" primaries, that's sick and cool.
I talked to the Hedman guys, they weren't that friendly or helpful. They just said "Nah, won't work". Didn't really jive with their offerings and listings, but I just got tired of fighting to get some info from them, figured I could get some better info here.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i am not sure those tight 2inchers shorties would be any better than a good set of 1 3/4 long tubes like hookers
unless your making like over 500hp or so, you can benefit from bigger tubes but how many do that?
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Hedman makes "Hustler" 1 3/4, 1 7/8 and 2" primary long tubes for our chassis, but they require a mini starter and a remote oil filter. Living in CA, I would also have to install AIR fittings and get them referee'd for smog. I'm considering it, but it seems like a lot of hassle and expense, and for the planned hot street engine, I don't think it will make that much difference. Just thought I'd throw it out there.
Troy
So Cal
Troy
So Cal
Car: 89 Iroc-z
Transmission: TH400
Well I'm looking to make 600+ on the motor. 441ci 12.5:1
Like these...Heddman Hustlers with 1 7/8" primaries 3.5" collectors. Mini starter for sure but you can get by without a oil filter reloctor kit. Just have to use the short filter.
Edit:
For what it's worth the adapter you have to run to fit big tube to the sbc needs to be completely ground out by the installer. The adapter comes with little 3/4" or so hole in the location needed, but you must manually grind them to fit the gasket.
Edit:
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
If you look at those headers posted, the bolt holes are not in the proper SBC places - you will need adapters (or heads with the correct bolt pattern).
Originally posted by phoenix305
hey paul_huryk how is your 350 a LG4? just curious.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
nice just curious, and its that fast with all those stock engine components?
I believe pauls pass in the sig was made with the use of nitrous.
Stahl headers?
Besides relocating the brake lines, steering shaft, AC removal, etc etc. - Do you realize how much you have to chop up the front end of the car to get those on right? Not your simple slide in place and bolt up...
I've seen them on a blown SBC IROC some time ago. I commented on his home built headers. After telling me about what he had to go through to get them to fit the car, he stated he would NOT do it again.
Stahl headers?
Besides relocating the brake lines, steering shaft, AC removal, etc etc. - Do you realize how much you have to chop up the front end of the car to get those on right? Not your simple slide in place and bolt up...I've seen them on a blown SBC IROC some time ago. I commented on his home built headers. After telling me about what he had to go through to get them to fit the car, he stated he would NOT do it again.
Originally posted by paul_huryk
Very easily - I swapped the 305 out for a 350 while still using the factory LG4 carb, distributor, and computer.
I have a Corvette 350 block, with Corvette wheels and brakes. Does that make my car a Vette?
Car: 1987 Iroc-Z
Transmission: 700r4 w/ about 7500 miles on rebuild
dude.. must we all find everything to pick at each other for? jesus
He was using the stock LG4 intake and firing components.. Not an LG4, but its saying that the LG4 intake and firing components are just fine to go that fast, thats all
Car: 1989 Iroc Z L98
Originally posted by Boomin Boy
i dont think you'll need 2 inch primaries until you're around 1000 HP IMO
Car: 83 z28
Engine: 300hp 355
Originally posted by unknown_host
Its about displacement and rpm more than just horsepower. Look at big block headers.
Car: 87 T/A
Ah well, I talked with everyone and their brother. Aything over 1-3/4" is out for the Firebird. Apparently for the 82-92 Camaro, there's a little more clearance along the body rails than the Firebird. Who would have thought?
So, I guess it's Hooker 2210's for me and my SBC 441...
its still a small block so im assuming its under 454 cubes and spinning at less than 8000 rpm..still too big IMO
Its not going to make or break his motor, I Just know people who have seen gains making less than 1000 horsepower by going to a larger header.
There is a general consensus on this forum that no motor should EVER need more than 1 3/4" headers and single 3" exhaust. I have been trying to break that for a while now.
Sounds like you have some badass cars, what does the malibu run out of curiosity?
Car: 87 T/A
4.125" stroke, 4.125" bore, 6.125" rods. Yes, I'll be taking some pics soon as it goes together...
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
Here's a picture of the 2" Heddman Hustlers that I have. Sorry as I have yet to install them yet though "still gathering cash & parts"
The folks from Heddman say that you will have fitament problems with stock pieces. I have a tubular K Member & will be using a mini starter. They have a steep price tag as well, a dab over $750.
Hope this helps, Bruce
Car: 89 Iroc Z
IHI is correct ("as normal") as the supplied steel adapter plates leave a lot to be desired & will need a lot of grinding to match the exhaust port pattern of your heads. I tossed them and made a set of them from 3/8" flat aluminun "lighter & easier to work.
Oh yea, the $750 price included the Jet hot coating.
Bruce
Bruce
Spend enough money and screw enough stuff up eventually you learn things
Car: 89 Iroc Z
Interesting collectors on those...
Car: 89 Iroc Z
Originally posted by IHI
LMAO, whats that supposed to mean??
Sell it, best advise ever!!
Car: 89 Iroc Z
I would agree with you if it was a n/a motor, but i am assuming from his sig he is going to still be running a 200 shot on this motor.
unknown_host, I agreewith ya.
When I built the engine in my signature I refered to a recipe from The Best of Hot Rod magazine "How to build Big Inch Chevy Small Blocks". They had dyno results & to make a long story short, the large cube small blocks made more HP & torque with the larger 2" tube headers. Also the enging they were testing was N/A
IHI, "Sell it, best advise ever!!",
Great advice, but I'm hooked & it's a lot of fun " I Think"!!!
Axle/Gears: 9bolt
I was getting some powder coating done, and was looking through the sample book the powder coater has. It listed a "super high temprature" powder coating, that is either satin black, or a finish that looks a lot like the ceramic coating. Anybody ever used high-temp powder coating on their headers before?
I have'nt seen any high temp powder coated headers, but I can attest the the fact Jet-Hot is simply amazing to say the least. We race with a couple from MN that had the headers for their 66 stang done by Jet-Hot, literally 2-3minutes after they're back in the pits you can grab the headers.
I was going to send mine out before installing the motor, but figured with all the headaches these 3rd gens throw at us, I better run them first and let the dents, dings from fitting take place before I spend $277 (quoated from J/H) to have then coated. Glad I did, Hooker Super comps + wheelies = A-arms slamming into the headers and denting the pipes badly.
But with our extreme under hood temps as they are even stock, coupled with the fact of poor air circulation by factory design, the thermal coatings is a great investment.
70GTO, sell it!! Take up yard work or something, these cars are like drugs as they consume you and take over your life!!
Least with yard work you can get your money back outta the place when you sell....try saying that about a project car
LOL!!
LOL!! Supreme Member
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Just bought a set. I think I am going to run Flowmaster Topten 3.5" mufflers off the headers and just turn them down. I don't know how gret my ground clearance is going to be...
Anybody have toptens?
Car: 87 T/A
Those will never work with your car!!!
I'll help bail you out. Tell you what, I'll cover the cost of what you had to pay just cause I'm a nice guy...
Those do look sweet...
Transmission: Th350
Car: 92 Z28
Engine: Boosted LSX
Its JUNK.. I do ceramic,thermal and powder coating. The Hi temp powder is JUNK.
Car: 87 T/A
Digging up this thread...
I went ahead with some 2210's on that 441. With some dyno-shop 1-7/8", the motor made 680 at the crank. With the 2210's and a dual 3"->3-1/2" in the car, it made 440 at the wheels. Getting rid of the Y-pipe and running open headers on the 2210's, it got up to 530hp at the wheels. That's too much loss, and I'm looking now to step up the header sizing.
Anyone have some insight into fitment issues? I've got an 87 T/A, tubular K-member, mini-starter, remote-mounted oil filter, Dart Iron Eagle spread-rail block, T-56.
I'm really leaning toward some 1-7/8"->2" stepped Hedman Husler headers, part # 65172. Any thoughts are certainly welcomed.
And, of course, if anyone has something along those lines, I'd love to hear about it.
And, if anyone needs some coated 2210's with Y-pipe, bullet, and Borla system out back, you know where to find me. What's restrictive for me could be wide-open for another ;^).
Car: 1987 Iroc-Z
yah, you are losing a good 30-50hp at the rear wheels (not sure on the loss of power with the T-56).. Have you thought of having custom headers made? i mean, with how much you put into the motor, it would be worth it and you could have whatever O.D. size you want.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Tim
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Heck, it doesn't look like even a 4" Mufflex system is big enough for your motor. However it would be a step in the right direction. Two 3" pipes in and a 4" out at the wye.
By the way Jerrywho who started this post wound up making his own 1 7/8" headers. The man has a lot of skills and never ceases to amaze me. Allen
