Two questions for the masters!!!!
Old Jan 12, 2005 | 08:40 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Question 1:
My water pump is about to take a dump and I was wondering if any company made a high performance one?
Question 2:
I have a laptop computer. Could you guys and gals tell me what software and what cables I would need so I can tune my car in the future?
All of you help is very apprecciated.
Old Jan 12, 2005 | 08:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I really havent found a true high performance one. I found one that claimed to more more gpm, but I cant really notice it.
Since you have a 90-92 that uses the 7730 ECM, nobody has made a program to read the v6 ECM. Member here "Pasky" was working on one, and I was trying to assist. Never did get one that connected properly.
Old Jan 12, 2005 | 09:28 PM
Karr1986's Avatar
Car: 1986 Pontiac Firebird
Engine: 173, 2.8litre MPFI V6
You might Try www.jegs.com. They probably have what you are looking for. As for comp programs. It was rummored a few years ago that Popular Mechanice and writted several CDs that had everything anyone could ever need for car service. You might see if you can still find one
Old Jan 12, 2005 | 10:16 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
actually....TunerPro R/T does have the ability to read our computers!
Old Jan 12, 2005 | 10:21 PM
Doward's Avatar
Correct - TunerPro R/T will read the .730, and modify it.
To burn chips, I'd suggest the GP1 and FnB from Moates.net!
Old Jan 12, 2005 | 10:55 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
What about the MAF ecms? What software do I use?
I ahve the ALDL thingy, burner, laptop and a few pieces of software
Old Jan 12, 2005 | 10:59 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
So far as I have found, the 7302 guys are stuck using Diacom and TunerCATS. Supposedly WinALDL will work with the 2.8s, but I haven't gotten it to communicate quite yet (haven't tried very hard either, though)
Old Jan 12, 2005 | 11:01 PM
Doward's Avatar
'302 uses WinAldl, but you have to ignore the data coming through - it reads it fine, but screws up teh conversion.
I've been using the RAW output, and converting myself!
Old Jan 12, 2005 | 11:11 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Airtex makes a good waterpump for our cars. The impellor is nicer than the Delco units. Its what I'm using currently and gets very good flow. I will be swapping out soon though for an electric pump (custom setup) so the motor robs less power.
Old Jan 13, 2005 | 07:07 AM
Doward's Avatar
w/b!
Old Jan 13, 2005 | 09:17 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've made a .ads for a '91-'94 3.1L LH0 motor (uses the $A1 code mask on a 7730).. You can create one from the datastream definitions... Is there still not a .ads for use with 90-92 F-body V6's in TunerPro RT??? If not, I'll make one... Somebody will have to test it though, as I don't have a V6 f-body..
Old Jan 13, 2005 | 09:45 AM
Dale's Avatar
Engine: 350 S-TPI
I have a laptop, and cord. I'll test any program you give me.
Old Jan 13, 2005 | 11:10 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A reverse flow water pump would be nice.
Old Jan 14, 2005 | 05:36 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
The "Download ALDL Stream Definitions" at TunerPro's website (http://tunerpro.markmansur.com/) shows a definition file "1227730_v6_90-92.ads" for "1990 - 1992 V6 - 1227730 ECM, 8192 baud" cars.
How about an ADS for the 1227302 used on the 2.8L cars?
Old Jan 14, 2005 | 05:40 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Doward has the info to do this (what variables are where in the stream and the conversion calculations).. just need to modify one of the existing 160 baud stream definitions to suit.
Old Jan 14, 2005 | 06:05 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
I took a peak at the ALDL Definition editing in TunerPro R/T. If Doward could send the data he has my way, I wouldn't mind playing around with it to see if I could get something going...
I did find a generalized stream definition in ALDLstuff.zip at ftp.diy-efi.org/pub/gmecm - file A20 in the ZIP, but I would like all the info I can get.
Old Jan 14, 2005 | 06:14 PM
Doward's Avatar
Already done, but the 160 baud in the current TunerPro is... flaky... at best. I already spoke with Mark about it - it'll be coming either in TunerPro 4, or shortly after, in an update.
Old Jan 15, 2005 | 02:20 AM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
So you mean to say that you've made a 1227302 ALDL Stream Definition and it will be available upon the next release of TunerPro?
Old Jan 15, 2005 | 06:17 AM
thirdgen88's Avatar
Car: 1995 Corvette
160 baud support will be better in Tunerpro 4... I'll see if I can make a .ads for that; you can test, correct?
Old Jan 15, 2005 | 07:59 AM
Doward's Avatar
Correct - I've already got a .ads built of the full '302 datastream.
Old Jan 15, 2005 | 11:48 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
Yes, I can test it out.
Excellent! I look forward to using the ASD with ver. 4 release of TunerPro.
formula1lle
Jan 29, 2016 10:56 AM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
