Great cheap rear upgrade
Old Feb 21, 2005 | 02:11 AM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
OK,this topic may have been beat to death, but I am so happy I must post!! I have a 85z that came with drum rears. I went to a pick and pull and grabbed a 87 rear disc. After the install, I was not real happy. Last weekend, I did the bolt mod(very easy!!) and you wont believe how much better the car stops now!! I did auto cross the car today and I was able to point and slow down SO much better then this car has ever done since I have had it! Man, what can I say!! I am so happy with this cheap ($$) upgrade!!
Old Feb 21, 2005 | 11:33 PM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
Ok. I'm lost. What bolt mod? Please explain.
Old Feb 21, 2005 | 11:38 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
ditto.
Old Feb 22, 2005 | 12:28 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
im thinking the bolt in the stock combination valve when you take out the plunger and all that maybe? I did it to mine but it's still restrictive. but i do have the pre-pbr disks also.
Old Mar 3, 2005 | 05:46 PM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
Ok, here is what I did. On the portioning valve, there is a bolt on the bottom, remove it and take out the spring and valve. Then, I drilled out the bolt with a size 8 and tapped it (it's a real smaal one) I installed a small allen set screw and put thread lock on it. Reinstall the bolt and bleed brakes.
This is what I got. I autocross the car all the time and the rear disc's have always looked rusty and I just installed 900lb front springs and before the mod, the front brakes locked up real bad. Now, no lock up and I have shiny rear disc! The car stop's very fast.
This mod was done on 85z that came with factory disc/drum setup and I installed a disc rear myself. Cost was the best part. I think I spent $12 bucks for the drill bit, tap and allen set screw.
Old Mar 27, 2005 | 08:18 AM
Verviticas's Avatar
Engine: L98 5.7
im interested in this project, but after reading your post several times, i still dont understand what you mean by drilling the bolt,
Old Mar 27, 2005 | 08:41 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
you dont need to drill anything, find a spare combination valve and take it with you to a bolt/nut specialty place or lowes had one that worked for a friend of mine that did it.
Old Mar 27, 2005 | 10:12 PM
Verviticas's Avatar
Engine: L98 5.7
Any of you happen to have pictures? If not don't worry. Ill just pick up a 1LE valve. My rear breaks are weak. And its all new and 89 pbr's
Old Mar 27, 2005 | 10:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
What exactly does this mod do or what is the indended purpose of this?
TIA
Old Mar 28, 2005 | 01:23 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
it allows more pressure to go through the line unrestricted. That's why you use a adjustable proportioning valve. If it quits raining I'll snap a picture of ow I did mine. I don't know what that guy did. Now that i've been thinking about it though. I would have rather just skipped the combination valve all together.
Old Mar 28, 2005 | 02:02 AM
Verviticas's Avatar
Engine: L98 5.7
i wounder if running full pressure to the rear will make it perform better......i suppose if you had some nice wilwoods in front (the 4 pot kind) it might work. (lock the front before the rears i mean)
but no tuning....
Old Mar 28, 2005 | 02:59 AM
MonkeyWrench's Avatar
Car: 88 Iroc-z
Engine: L98 350
http://www.cardomain.com/memberpage/205049/10
not my car but maybe help
did it to my car befor i put c4 hd's on the front, 98 ls1 rear end in and a adjustable pv and it did help alot but the back brakes do lock up first whith the mod so take care brakeing hard in the corners
Old Mar 28, 2005 | 07:41 AM
Verviticas's Avatar
Engine: L98 5.7
I feel like a moron, i understand completly now.
Anyone happen to know what is the correct hex nut to use as a replacement plug?
Old Mar 28, 2005 | 12:50 PM
Car: 88 Iroc-z
Engine: L98 350
the thred size is 5/8" - 18
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
