Hardtop to vert?
Old Mar 20, 2005 | 12:48 PM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Hardtop to vert?
I see they started with a t-top car for the conversions, I have a parts car outside the shop with a t-top roof that I was most likely going to put on my formula, but, I'd much rather a vert. Anyone ever done a conversion and any idea where I could find some of the parts required? I realize chassis strengthening will be required but that's not a big deal for me to do and I was planning on adding some structural bracing to the uderside regardless. Is the only way to find parts to buy a wrecked car or is there a source to find them from? Just wondering and researching...
Old Mar 20, 2005 | 03:16 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
This topic has beeen covered in here before and the general consensus was , just buy a convertible. Honestly by the time you track down everything your gonna need to do the conversion you're probably going to spend what a decent convertible is gonna cost you. So why bother doing the conversion? Its up to you but these cars were pretty low production and I would assume finding wrecked ones is not an easy task. Finding the parts separately will be very difficult. In the end your car will not be a factory convertible and ultimately not even an authorized conversion by any of the known conversion facilities so getting a good dollar value for it might be difficult. Just my .02 cents
Old Mar 20, 2005 | 06:59 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
all you need is a sawzall ;)
Looks like you got a fabrication shop. Well, maybe this would be a project for you but I still agree with Zedder. The payoff for a project like that might not be all that.
If you decide to do it, I would request full, photographic documentation. :-)
Old Mar 21, 2005 | 07:27 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
been there done that.....
Do a search on my username..
I took my 92Z and a Totaled 91 RS vert. 1+1= a T top Z now converted to a mini tubbed vert.
here a quick tossed together page for a example.
http://www.cecoatings.com/DropTopZ.html
You want more specific pic's let me know what you need.
http://www.cecoatings.com/images/Car...s/DSC01120.JPG
http://www.cecoatings.com/images/Car...s/DSC01122.JPG
Here you can see the vert in the garage beein striped
Here Im still moding the size vert caps that hide the seam of the vert conversion. So my 91-92 Wing fits.
If you have a sawzaw or Plasma cuter like I did. and You can weld I say go for it. If you can find everything needed.
I scored the complete vert, leather Int. in MINT condition for under $700. So for me being able to fab it all up. It was well worth it.
My Z already had a complete suspention setup. SFC's LCA,STB,Springs,Shocks, Etc..
Old Mar 23, 2005 | 06:45 PM
Fast-Tony's Avatar
Car: 85' IROC & 87' IROC conv
Engine: Both have Vortec TPI 350
Transmission: T-50
Axle/Gears: 3:42 & 3:73
I am glad to see I am not the only one with too much time on my hands, I have done a T- Top to convert conversion I bought an 88' IROC convert for $500 that was totaled in the front and piece by piece disassembled restored then converted my 87' IROC it is exactly the same as ASC did it just awaiting paint. I can say once is enough.
Attached Thumbnails Hardtop to vert?-d-camaro-files-87
Old Mar 23, 2005 | 06:52 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Wow, Im not the Only crazy one on this site then huu..
Anymore pictures you could post?
Did you use the complete inner structure? Thats what I did. wasnt as bad as I thought it would be to do.
Just wait till everyone sees what i take on next for the front end of the car.
heres a Hint.
Old Mar 23, 2005 | 08:06 PM
Fast-Tony's Avatar
Transmission: T-50
I have most of it on video instead of pictures, I used every part from the 88' I had to cut my fenders, table saw the rocker mouldings because the 88's were junk and so on. I did some improvements while I was at it like access holes for the rocker moulding rear studs and the rear trough water drain hoses now come out in rear wheel housings I didn't want water draining into the inner rocker panels. What made it more fun was I did it in a tight rented garage that did not have any power I used a generator and portable welder.
Tony
Old Mar 25, 2005 | 04:24 PM
TPI383, I like how you kept the tall spoiler on your car, looks so much better IMHO. Nice to see this has been done before and that I'm not totally out of my tree. I also located a whole car that's been wrecked in the front, just need to sort out how to ship a non-running, non steering, non rolling car from texas to mass at a reasonable cost and I'll most likely do this myself... Unless of course anyone knows of a complete, wrecked vert more locally, I'm all for it
Old Mar 26, 2005 | 11:52 AM
Fast-Tony's Avatar
Transmission: T-50
TPI383
You asked if I had anymore pics that got me thinking so I took some today the one I posted was 5 yrs old. I mentioned I did some extra mods some of those are 1-1/2" X 1-1/2" X 1/4" thk angle 304 Stainless steel reinforcements to the bottom of the ASC rocker panel reinforcements. I also have pics showing the modified hose drains comming out in the rear wheel housing. Many of the car designs from several manufacturers drained water into the rocker panel I really dislike that is causes rust, the 3rd gens got away from that but ASC didn't get it. I am planning on building a garage/barn later this summer maybe next winter I will finish up with the paint? I took over a dozen pics today but have not been able to post more than 1 if you would like to see more just ask and where to send or how do you post more than 1?
Thanks for asking.
Tony
Old Mar 26, 2005 | 05:33 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Well, hey,
Make that video avail for $15 a copy and recoup your losses. Sounds way-cool, as they say
I think the key is finding your donor then eh?
My hats off to your visionaries who do it for yourself FIRST and not to get some bucks when selling down the line.
No one would argue that that's a great thing, but REAL custom cars are in short supply as I see it, even as factory mods
Bill
Old Mar 26, 2005 | 05:41 PM
Bill Speed's Avatar
Engine: L98 350 TPI
Fast Tony:
For your pics, try resizing them with the software that should be with your camera, or equivelent. Make sure they fit in a standard page. I had to scroll left and right to read! hehe
-B
-Or email the pics to me for editing, I can do 'em when I have them saved to my HDD
Old Mar 26, 2005 | 06:03 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
E-mail me the pictures I will host em for you like I do TONS more here
Its my little space for pic's for people.
http://s89724942.onlinehome.us/images/
Just a small 500meg host I use for everyone else to post pic's
my e-mail is
chris@cecoatings.com
I'll make and lable a folder for your car in the vert folder.
Old Mar 26, 2005 | 07:20 PM
Bill Speed's Avatar
Engine: L98 350 TPI
I like including pics in emails, so normaly they're small enough to attach... my email is billschwenke@aol.com, BTW. I usually miss the PMs here as they don't update me on them
Bill
Attached Thumbnails Hardtop to vert?-c-windows-desktop-video
Old Mar 26, 2005 | 08:09 PM
Fast-Tony's Avatar
Transmission: T-50
I was surprised the post went through I was emailed it didn't go because the attached file was too big, I put the pics on my yahoo photo album today I will send them to chris maybe he can get them on for me. I did the job 5 + years ago originally just wanted the convert reinforcements adden to the T Top car for strength but I really like the top style so out came the can opener. The video is in my collection somewhere I will double check to see how much of the convert conversion made it on the tape? I also did a detailed restoration on the whole car includong stripped the entire underside floor and painted it with urethane paint, even though the car has only 50K the paint underneath was getting old. I don't go to many shows or do my work for show purposes I just like detailed really clean cars all around. I have owned the car since 91' but not used it yet back burner project. My 85' IROC is my pride and joy detailed over restorred and built beyond
my dreams. Thanks guys I look forward to this site like my monthly Super Chevy Magazine.
Tony
Old Mar 26, 2005 | 08:42 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
here ya go...
Perfect size for posting pic's
http://s89724942.onlinehome.us/image...les/Fast-Tony/
Old Jul 7, 2005 | 11:09 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
heres a Hint.
do u have a larger pic of that tilt front end!
Old Jul 7, 2005 | 11:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.cecoatings.com/images/oth...0Front%20Clip/
Old Apr 2, 2006 | 12:46 PM
brandonz28's Avatar
Car: 84 z28 'IROC' clone
Originally Posted by bottledbird68
wondering if you have any more pics of the 83? im really liking the hood
Old Apr 2, 2006 | 01:12 PM
I have plenty, what would you like to see? It's a factory 83 z fiberglass hood with an 82, ahem, mustang gt, ahem, hood scoop. The things you do in an emergency when you realize the new setup doesn't clear the hood.....
Old Apr 2, 2006 | 01:14 PM
brandonz28's Avatar
i would love to see som more of the hood! i think it looks really cool, and theres not alot of 3rd gen hoods i like
Old Apr 2, 2006 | 01:28 PM
here's a good one
Old Apr 2, 2006 | 01:31 PM
brandonz28's Avatar
sweet i like that! do you have any pics of the hood in the process of making it? or how was it put together?
Old Apr 2, 2006 | 01:47 PM
All I did was cut a hole in the middle of the hood for the air cleaner, take a few measurements to center the scoop, drill the holes for the factory studs, and bolt it down. Quick easy and painless. The hard part is finding a good scoop as they only came on 79 pace cars or 82 GT's
Old Apr 2, 2006 | 01:50 PM
brandonz28's Avatar
that could be something to look into... do you have any hi res pics of the outside like the one in your sig? i want to see what it would look like on a black car
Fireslash
Apr 11, 2016 06:43 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
okfoz
Oct 13, 2015 02:19 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
