manual fan switch, how to?
Old Apr 14, 2005 | 08:40 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
my l69 single fan carbed h.o. engine has no more xcomputer in it at all, My a.c. switch will turn on the fan, as it should, I want to hook up a manual switch seperate from the ac control on the dash. I dont have a problem using a manual switch to kick this single fan on when needed on occasion, the car doesnt overheat that much. How would I hook up a simple toggle switch and intergrate it into the two wire plug-in going into this single 16" fan? Like I said before, Ive no computer running anything on this car including the trans. any help on this would be greatly appreciated so I can get it done before cruising season starts soon.
Old Apr 15, 2005 | 12:41 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
For me i did the Following:
Old Apr 15, 2005 | 12:43 PM
Car: 85 Trans Am
oops
Old Apr 21, 2005 | 05:21 PM
ricktaylor's Avatar
Car: 84z28
what kinda relay?
Thanks for the diagram, I printed it. Im curious tho- Forshock,, am I using the existing relay for the a.c. or a whole seperate one? It seems a new one completely and if so what type and where to get it? Also I could probably use the existing plug in that goes into the fan, providing I cut it and incorporate it into the wiring diagram you sent me, right?
Old Apr 21, 2005 | 05:38 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
You can use the same relay. Can't remember which color wire (green maybe, or green white stripe), but turn the ignition to the on position, and probe the wire with a test light and the fan should come on. I used a 2 position switch. Connected one wire to ground and the other to the relay. Hit the switch and the fan comes on.
Old Apr 22, 2005 | 01:18 PM
Car: 85 Trans Am
I didnt have an AC relay to use so i had to get one. If your ac relay works, just us the switch setup into the existing relay.
Old Apr 22, 2005 | 04:31 PM
ricktaylor's Avatar
Car: 84z28
fan relay.
Appreciate the reply back, my relay works fine and have the colored wires described. Its exactly what I was looking for, simple, and set up right. Thanks for the help.
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
