Have you seen this intake?
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
I was wondering if anyone has seen this intake before? here are three pictures. Thanks for any help.
No, I take that back, maybe it's just a modified TPI plenum. Not sure what kind of runners those are.
The first system has plate on the front driver side so you can side mount the TB if necessary, that pic doesn't seem to have one.
here are some more pictures, yeah, it looks like stock but it's different
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The runners are modified SLP. Here is a picture. This modification picked up 21RWHP and 23RWTQ. Peak horsepower is now at 5000rpm and peak torque is at 4600RPM.
Engine: all 225+ RWHP
Transmission: all OD
Well, its certainly not factory by any means that I can see, the runners and intake base for sure.
The runners are more oval than round. Plenum looks like possibly some type of aftermarket, cant really tell with out more pics of it.
Have any type of emblem or labels on it? I see casting numbers on the plenum, that may shed some lite there. Also looks like some numbers/letters on the base. throw those out too.
Lots of folks have made TPI parts over the years and quite a few places folded in the 90-95 range as well. changed names, went out of business or quit making stuff period.
Possibly a rare 1 of 100 run that made it to production or something that was being prototyped to the point of production possibly.................................
Give us any details that you can.
later
Jeremy
later
Jeremy
I am buying it from another person But I will add more updates as they come. Thanks for all the help everyone
Re: Have you seen this intake?
Now the bad news you will find the machine work is not good (not production) and the casting is one off, so port match and wall thickness will be all over the place and little things will be not right or why is this not in the right place. It was a test part thats why.
The bad part about is now you can get aftermarket parts with no fitment problems, be smog legal and go faster.
Jerry
A couple more things look at the bottom plenum its for S.D. not a MAF car are you installing it on the 86 in your sig. and if so have you converted it to S.D. Also what type of external EGR are you going to use note no EGR passage on the runners.
Jerry
Jerry
I did not know that it would not work for MAF, it would be for my 87 iroc. I am also not using the egr.
Jerry
My car has the 9th injector now. So you think I would be better off looking for aftermarket than using this intake?
Car: 1994 Trans Am
I'm not being a smartass, I'm just totally confused with things I can do to the TPI to flow better. Some say porting does nothing and you will only gain a tenth if I'm lucky. However, 21whp and equal torque should help out quite a bit. More than a tenth anyway.
Car: 1989 GTA
Engine: 369 TPI
Howdy BigWhiteGTP
The post above is correct in that they are "HEAVILY" modified SLP runners. The Edelbrock intake is not siamesed. However it is Extrude Honed to 1.70". Basically the Plenum was made larger and no cylinders will be starved. The runner length is now somewhere between 11 and 12 inches.
My new times are posted below. I estimate the weight of my fully loaded GTA at 3550 pounds plus my weight of 250 pounds. With the addition of a YankSS3600 stall converter to replace my SLP 2400 converter and the TPI modification I picked up .6 of a second in my et. I also picked up 2+MPH.
I figure the TPI mod and the Yank SS3600 both picked up .3 of a second. Allen
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
i heard that doing that will cause distribution problems, cylander going extremely lean and so forth, has anybody else heard of this?
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
In other words, lots of plenum, shorter runners - no reason for air starvation. But on the other hand, one might ask himself - why not just get a superram as this point?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'll let maximus de mad take this one.
I bought the intake in this thread.
Once I clean it up and have some time to play with it, I will post more pics.
Jerrywho, can u post some pics of your lt1 prototype intake.
anyone who has pics of information on prototype intakes are more than welcome to share if u have something.
We know next to nothing about factory stuff tested on these cars outside of a few shwocase cars built
later
Jeremy
later
Jeremy
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
I have one for sale on the Corvette Forum C4.....its a Rare factory TPI designed for 5.7 motors not too many around mine came from LPE
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
