not the same speedo gear question
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Alright I've done the search button a dozen times. I'll spell it out really simple. I have 91 t-5 with factory 3.08, and 235/55/16 tires. So the speedo gears are 9 and 22. I am putting a 3.42 rear in and I currently have 225/60/16 tires. Which would mean I need a 23 tooth gear with the factory 9 tooth. However I can't find a 23 tooth gear part number, and I don't think it exists. Also in the summer I plan on changing to 245/50/16 which would need a 24 tooth gear, which I also think does not exist. I have changed the gear that rides on the mainshaft in a 700r4, however I have read that changing the gear on the mainshaft of a t-5 is much harder.
1. Do 23 or 24 tooth speedo gears exist for the t-5 and part numbers?
2. Is there a guide for installing the speedo gear that rides the mainshaft of the t-5? Considering I'll probably have to go to 7 tooth gear.
3. Is my math right?
4. Can we eventually get a simple sticky with all the colors, part numbers, and teeth for both the 700r4 and t-5?
Car: `86 SS / `87 SS
1. Yes. I can get them; I just haven't done much in sales lately because my new job is differently located.
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Re: not the same speedo gear question
https://www.thirdgen.org/newdesign/f...n.shtml#tranny
scroll down to the 2nd article.
Q: I want to buy speedometer drive/driven gears, what are the part numbers and combinations?
Car: 91 Camaro RS
Sending PM to you jmd, the problem with the faq is it only lists 700r4 part numbers.
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
[QUOTE]Originally posted by Gladstoneiroc
[B]Alright I've done the search button a dozen times. I'll spell it out really simple. I have 91 t-5 with factory 3.08, and 235/55/16 tires. So the speedo gears are 9 and 22. I am putting a 3.42 rear in and I currently have 225/60/16 tires. Which would mean I need a 23 tooth gear with the factory 9 tooth.
Don't you mean a 6, 7 or 8 tooth one?
http://www.hanlonmotorsports.com/t5speedo.asp
I have a 7 tooth one and a 21 tooth gear for the stock tire size (245/50/16) and a T-5...
Car: 91 Camaro RS
I have read on TGO that cars with 235/55/16, t-5, and 3.08, had a 9/22 combo (88-92 or so on years electric speedo) Is the drive gear that hard to change or is it as easy as a 700r4?
I used the hanlon calculator and other basic math to determine what I needed with 9 tooth drive gear
Engine: LS3
Transmission: 6L80E
I just used the Hanlon calculator...and it doesn't mention a 9 tooth gear!
That is my point...
Are you sure that you are right about that?
Better yet...does GM make a 9 tooth gear? I hadn't heard of that...
That is my point...
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Engine: TPI
Engine: TPI
Well, I don't know of a 23-tooth driven gear for a T-5 VSS.
So your only bet is the 7/19 combination. That would get you close enough (<5% off).
Oooooorrrrrrr ... if you can locate the 8-tooth drive gear (#6261783), get a 21-tooth driven gear (#14090594) and that will get you as close at 1% off on your speedo.
Hope this helps.
Lou
Hope this helps.
Lou
Car: 91 Camaro RS
Is changing speedo gears in a T-5 the same as a 700r4? Pop the tailshaft off remove the pin hammer the old gear off and hammer the new one on? If so its not a big deal. I'm going to down with these part numbers to my local gm tonight. I would have them look them up however they aren't that bright.
Car: 91 Camaro RS
Can I get the part numbers for the electric VSS for the
(prices from GM list)
7 tooth #14071731 $5.95
8 tooth #6261783 $12.14
9 tooth #14053347 $6.14
18 tooth #14090591 ??????
19 tooth #14090592 $23.78
20 tooth #14090593 Discontinued
21 tooth #14090594 Discontinued
22 tooth #14090595 $23.78
23 tooth
24 tooth
I can either use a 7/18, 8/21, or a 9/23 or 24
23 tooth
24 tooth
Engine: TPI
7 tooth - #14071731
8 tooth - #6261783
9 tooth - #14053347
18 tooth - ?
19 tooth - #14090592
20 tooth - #14090593
21 tooth - #14090594
22 tooth - #14090595
23 tooth - ?
24 tooth - ?
8 tooth - #6261783
9 tooth - #14053347
18 tooth - ?
23 tooth - ?
24 tooth - ?
Car: 91 Camaro RS
BigBabyLou, your 20 and 21 tooth part numbers aren't showing up in GMparts direct. If I have a chance I'll go down to GM later and ask them. I also email GMparts direct, however I doubt they will be of much help.
Engine: TPI
You could also try calling 1-888-877-1008 (Performance Automotive and Transmission Center - Speedometer Calibration Center). If they can't find it by the part #, describe the gears to them and they should be able to find them for you.
Lou
Lou
Car: 91 Camaro RS
Lou
Lou
I keep getting more and more SOL.
Engine: TPI
Xrist, that sucks.
I have one more idea. I'll PM you contact info on a great local guy (GM dealership tech) who knows a lot about these. Call him and if he can't help you, we gotta make you the gears ourselves.
Car: 91 Camaro RS
Xrist, that sucks.
Xrist, that sucks.
Also too bad that I have the 8746 and I can't edit the speedometer ratio in there.
Car: 91 Camaro RS
Finally got to calling BigBabyLou's guy, he came up with the best set being a 7/19, however there appears to be a "Brown" 18 tooth that was used in some fourth gens that should theoretically work, but we were time limited and it wasn't turning up easily.
Some one hack the 8746 to alter the speedo.
Car: 91 Camaro RS
Well the rear got put on hold when the transmission started having problems. I'm still going to get these problem solved though by summers end. I almost certain that I am going to run a 255/50/16 tire too. That would leave me the combinations of 7/19, 7/18, 8/21, and 9/24. Which would only really leave the 7/19 combo. Too bad they didn't make more speedo gears.
Car: 91 Camaro RS
Just an update and bringing another post back from the dead. The rear is scheduled to be installed over thanksgiving break, however I am still speedo gearless. I had a bunch of clutch problems which led me to an adjustable ball stud, that is why I am trying to avoid pulling the transmission. I already have the 255/50/16 tires, so all I am waiting on is the 24 tooth electronic speedo driven speedo gear.
Car: 91 Camaro RS
Will give $5 paypal cash to anyone than can find me a 24 tooth driven electronic speedo gear. I've been looking would any 700r4 or Ford gears work? I just don't want to pull that transmission again to put speedo gears in. It took miracles to work this time.
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 7, 2015 04:27 PM
