4th gen seatbelts
Old Jul 5, 2005 | 07:49 PM
irocyourpants's Avatar
Car: iroc
4th gen seatbelts
so just to make sure because i second guess myself---alot
4th gen seatbelts can be a complete swap into a 3rd gen car correct
are there any modding or "customizing" that needs to be done
thanks for all the help
Old Jul 6, 2005 | 08:38 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
They are a direct bolt in as long as you remove the bracket used to mount the floor retractor. It's held in by a couple of bolts. The floor mount will bolt right in after that. I have a set of them in mine and I used the cover from the old floor units as a cover and mounted it to the new ones.
Old Jul 6, 2005 | 10:48 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
can you post a picture of that? my brother's trans am has 4th gen belts, but as of now, there's just a gaping hole in the door sill.
Old Jul 6, 2005 | 10:51 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Three cheers for 4th gen belts!
Old Jul 6, 2005 | 02:08 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
The rear shoulder belts don't fit perfectly. They don't fit under those covers right, so you have to cut the opening bigger. Also, the thirdgen rear shoulder belts had kind of a T shaped thing to keep them in place, and the 4th gens have a fat tab to accomplish this. You'll have to grind either the opening in the thirdgen or the tabs on the 4th gen belts. But they sure do look good!
Old Jul 6, 2005 | 03:30 PM
Mongoose's Avatar
Car: 90 Formula
I don't have a pic but you simply drill out the rivet that holds the cover in place and you'll have to cut the old belt to get it off. I then slipped the lower mount through the slit in the cover (you may have to enlarge the opening a little) and then once you have it mounted on the floor line up the cover where you want it. I then used a self tapping screw in the rivet hole into the plastic of the new belt and viola! Make sure to have the lower belt mount good and tight or it will shift around.
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
