day/night sensor
day/night sensor
Hello everyone.
The lights on my car will keep cycling on and off every few minutes. This is happening at even 9:30 in the morning and depending on how the sunlight hits the day/night sensor you can predict when it will happen. My 02 silverado doesn't do this......
Should I disable the day/night sensor? or can I splice in resistor so it's not so sensitive?
Or any other thought suggestions.
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I'm experiencing the same thing and in my case it's most likely a dirty sensor or loose connection. My car has been sitting alot and I just swapped motors last season so I easily could have stretched a wire. It will flicker off and on day or night for a bit but figure out to stay on or off after a minute or two.
HoosierinWA
Oct 7, 2015 10:15 AM
