I'm gonna blow up my car!!!!!!!
Old Aug 13, 2005 | 06:13 PM
confucius101's Avatar
i need to kill my alarm system......
a few years ago i had installed a python b/s system with kill switch.
now i can not get the car started!!!!!
we've traced everything back to the alarm
pulled the brain out reset the batt.
but still nothing
we ended up having to start it right from the starter
we've never played with any of these new alarm systems b/4 so don't really know anything about them and how they work
when we killed the brain shouldn't that have killed all effects or would the kill stay in effect b/c it was allready activated
the shop that installed it will not be open untill tuesday so thats out
please give me some ideas guy's fast i've got to get this car back on the road asap......
Old Aug 13, 2005 | 07:26 PM
9177's Avatar
Check the starter kill relay. If you have removed it from the harness it won't even turn over (I assume this is the problem your having). If the relay is ok cut the ground when armed wire (should be orange). If you have already removed the alarm brain then you problem is with the relay from the starter. Make sure that wire is not grounded anyplace else, if it does the relay will be activated and you will not beable to start the car.
Old Aug 13, 2005 | 07:44 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The last three alarm systems I've seen in cars have a wire spliced into the big yellow wire on the steering column. This is part of the starter kill as well you may want to check there and if it is spliced into the alarm, connect it back together.
Old Aug 15, 2005 | 09:23 AM
Thanks a lot guy's
Old Aug 15, 2005 | 09:38 PM
net_coma's Avatar
This post answered my question. I have one similar on the car I recently purchased and I hate the dang thing. Now I know for sure that it is getting removed.
Old Aug 17, 2005 | 05:27 PM
WhitePower's Avatar
Car: 1991 RS
With these DEI alarms you should be able to just unplug the alarm module to bypass everything.
Old Aug 18, 2005 | 01:41 PM
thats what we thought but for some odd reason she still would not start so my uncle played around with the starter and got her running..... i have no idea what he did but she's been working fine i just have to get use to using a key and locking the doors myself again
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
jackhammer
Aug 15, 2015 10:04 PM
kyleb24
Aug 15, 2015 08:24 AM
