Power Door Lock / Latch Restoration
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
For all those that have 'sticky locks'...
Ive seen many say just spray grease all over, but you can barely see or get to the latch when its installed. Once I took a look it wasnt that hard to just remove the latch. You will also want to remove the piece that the lock solenoid moves, just drill out the one rivet.
Heres a before pic, the black grease is really very old and sticky.
Car: 86 TA
I cleaned it up using Zep 505 degreaser from Home Depot. Sprayed it a bunch then let it take a bath for a while. Worked quite well, heres a pic:
Car: 86 TA
Then spray white lithium grease from Home Depot all over the moving joints for both pieces.
Reinstall pieces (screw/nut for small piece), and power lock now works great!! Using original solenoids. Only one press required! Door also closes much nicer, always had passenger not completely closing the door but latching... what a pain.. should fix that too. Still have to do drivers side..
Also greased window tracks while I was in there, and door hinges. And used new design 2 rod holder (see other FAQ post on Door Rattles) and lubed those.
Let me know if any questions..
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
so, did your locks do what mine did? I press the power door lock button and i hear the solenoids but the lock moves very little and the door is still unlocked. I have to push the lock button maybe 3 - 4 times to get it to lock. Does doing this fix it?
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
WTG, Dig!
Car: 86 TA
yep, that's it. does it sound like you are sending morse code?, lol...
alternatively, you can buy new ones from Classic Industries for $205 EACH...
Engine: 3.4 / 5.0
yup....I'm almost positive I was doing S.O.S lol.....but $200+ for new???....hmmm.....I think I'll try this first
Thanks for all the tips!
Car: 86 TA
yes. there is 3 screws holding in on.
you will also have a bunch of rods connected to it you will need to disconnect (from memory):
outside door lock - a little plastic piece holds it on, it opens on one side, push it the opposite direction, the pull out the rod. hard to describe, but use a flashlight and you will see what i mean.
outside door handle - same as above, or you can just leave this one and move the latch down, its not connected
inside door lock - just unsnap the other end from the door, and bring it out with the latch piece, and remove later
inside door handle - this is the tricky one.... i couldnt figure how to remove from handle side, so i got a little screw driver and was able to bend the little metal piece to let the rod push out. a little tricky.. just have some patience.
if you mess up those little clips getting them off the rods,you can thread the rod ends and use little nuts threaded on the end of the rod with a drop of locktight on them to keep them from working their way off.Works great & only takes a few minutes to do.use a tap & die set to thread the rod ends.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally posted by Drew
Or you can just roll the window down and spray the latch with PB Blaster through the window opening. It really is that easy.
Car: 86 TA
Originally posted by firebirdjosh
Except the original grease + years of dirt cover the whole unit so a light coat of PB blasster on top doesn't do anything for half of the cars out there.
1992 Trans Am
May 10, 2023 07:19 PM
oh well it will just have to wait for another day.
