LT1 Intakes
Old Feb 12, 2006 | 12:29 AM
DF'sCamaro's Avatar
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
LT1 Intakes
Post some pictures for ideas of the best way to run my intake on my LT1 once swapped in.
Old Feb 13, 2006 | 01:28 AM
Firebat's Avatar
IF you have a camaro, then i would try to go this route. Takes up less space. If you have a 94-97, it would be a good iidea to get a 95 corvette intake bellow(for the iat sensor and optipark vent). If you have a 93 just get tubing.
https://www.thirdgen.org/techbb2/sho...highlight=pics
Option 2: get a lt1 elbow and get a cheap LT1 cold air intake off of ebay.
Option 3: If you have a 93, just get a filter that connects directly to the throttle body.
Option 4: Get a 3.5" elbow and custom cold air intake. This might work, not sure.
Option 5: Use the ram air box if you have an aftermarket ram air hood
Option 6: something else custom....
more links...
https://www.thirdgen.org/techbb2/sho...hreadid=342224
mine is option 2, with a flowtech elbow.
Old Feb 13, 2006 | 11:58 AM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I used a factory TPI box with a piece of pipe connector.
Old Feb 13, 2006 | 01:22 PM
TexasLT1's Avatar
Car: '92 RS
same thing here just with the MAF in place
Old Feb 22, 2006 | 10:33 PM
DF'sCamaro's Avatar
Car: 1992 RS Black
Axle/Gears: 4.10
Which one do you think would give out the most horsepower and air/fuel ratio's correctly? Here the setup I'm think of a stock top TPI box and the ram air box bottom that hawk sells. And I would have a piece of pipe or rubber connecting to the throttle body to the maf then to a slip hose to the top box. What do you guys think here the link of the
Ram Air Box
Old Feb 22, 2006 | 10:46 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Use the one that gives you the least restrictive airflow. Anything that takes air from a big area and then flattens out to almost nothing restricting airflow is going to cut power down.
Old Feb 22, 2006 | 11:03 PM
Firebat's Avatar
nevermind...already mentioned this on my previous post...
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
