help me find my way, lost
Old Feb 26, 2006 | 02:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Had the problem with the fuel pump, check and re wired fuel pump, thought it was just lose wires in back.
still acted funny where it wouldn't come on unless I wacked the fuel pump area.
so I put in a new pump. still not coming on all the time. So must be the oil psi switch [fp relay never work or has work for 7+ years but ran fine but pump never primed until I had oil psi]
so n e ways, ordered new oil switch but its not here yet.
But I had wired a maual FP switch to run it for now.
but now I am having problems starting the car, unless it sits for a while. Just turns over n does nothing, if you shut it off and try to start it back up, shot of either and it starts right up n runs fine.
changed plugs, cap n rotor for kicks, thinking well maybe with the new FP its runnin rich.
well that didn't help. pulled some plugs and they are all nice and white and dry. not floodin.
so I start playing with wires and when I yank the plug off the oil psi switch, the motor dies.
looking at the wiring in the book, the FP relay and oil psi switch wiring runs into a big blank box and ya can't trace it any farther.
Not sure what I'm thinkin here but somehow the fp relay n oil switch are hooked into the cold start and injector circut?
why would the car stall when I pull the plug on the oil psi switch when the FP is wire hot with a manual switch?
Only thing I can think of is, somhow removing that plug, killed power to the injectors. which might be only working cause of my hot wired manual switch on the FP.
or is the fp n oil swtich somehow connector to the ign?
I got the book of wiring but its not 100% clear, all the wires just run to a big blank box and ya can't trace them any farther.
wish they just listed the full wiring diagram, instead of chopping it all up.
Old Feb 26, 2006 | 03:53 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Even more confused cause I confirmed my symptoms.
with the plug yanked off the oil psi switch, the motor does not get fuel. It will fire on either and diesel but will not start. hook up oil psi switch and it will start. yank the plug, and the motor dies.
the FP is wired hot at the tank, on the tan wire. So it bypasses the whole wiring system, but I guess something else is bad, and its reverse charging the system, making it work. but??/???
I'm so confused on this one. none of it makes any sense.
Old Feb 26, 2006 | 05:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
OK it was all my fault, the system was being reversed charged and it didn't like it.
maybe it was the extra ground wire, I dunno. power wire is switch so it can't **** it off all the time. But once I clipped my manual wires for the fuel pump, everything was fine. oil switch works..... car start up no problem once shut off.
it all started like bad wiring and I hate getting stuck like that, so the manual switch was my back up fix but the computer does not like it. and was of course the FP all along but the way things acted lead me down this road.
oh well, tunes up are good anytime, weather you need it or not.
I can use the oil switch for my buick.
last 2 days of hair pulling just means it don't need cut for a while.
oh and to clear it up, the FP fuse is on the left fender well, facing the front of the car. Looks like a weather pack plug but has a normal fuse in it. orange n red wire run to it.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
angel2794
Sep 8, 2015 06:22 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
2QUIK4U
Aug 26, 2015 04:40 PM
