What fitting/sensor goes into this hole on plenum?
Old Aug 25, 2015 | 11:15 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Lost my notes and pics from when I took it apart. Thanks!
Old Aug 26, 2015 | 07:28 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: What fitting/sensor goes into this hole on plenum?
Based on the MAP boss and having THREE holes, that is a MAP/SD plenum. That also matches your profile: 91 was SD.
The three connections go to: AFPR, heater controls, MAP sensor. I am not sure of the factory arrangement, but functionally it doesn't matter which item is plugged into which hole.
Old Aug 26, 2015 | 12:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Use the vac fitting that fits the rubber 90* fitting on the map sensor.
Old Aug 26, 2015 | 04:40 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Thanks guys. I got all the parts! I want to do this job and not have parts left over like other jobs I have done. Thanks again!
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
drumstixer
Sep 29, 2015 03:02 PM
