Why does my heater fan work 'sometimes?'
Old Feb 26, 2006 | 09:33 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Essentially, my car tells me when I deserve to have the fan on...
It's kind of odd. First, the switch for high, medium, etc, does not directly control the fan. Also, I know my fan works perfectly fine, because sometimes, it will just turn on, really strong. I've found that, GENERALLY, If I turn the car on, turn the fan switch to full, within 15 minutes, it will come on. Sometimes it just doesn't. Also, sometimes If I turn it off, it still doesn't want to agree...
I would assume this is just a wiring issue, but the fact that on rare occasions, it will perform like normal.
Any thoughts while the car is disassembled?
Old Mar 1, 2006 | 09:23 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
You could just wire it so it runs all the time like mine. As soon as you turn the key on it starts running.
Old Mar 1, 2006 | 09:52 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
More than likely the problem is in your resistor block for your blower speeds. GM has had issues with them for years and still has them. the resistor is located next to the blower motor and will have two connectors, one that has two wires that goes directly to your fan motor, and another with 4 wires that connects to your blower switch and the fuse block. If you want to test, next time the fan will not come on check with a test light across your fan connector if the light does not come on you've got no power, check back to your resistor and check for power and ground more than likely you have both going into the resistor and are losing one before it makes it to the fan. Resistors of that style are fairly cheap and can be picked up at any auto parts store, or the dealer.
Old Mar 1, 2006 | 10:18 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Check the fan motor grounding wiring that goes to the back of the passenger cylinder head. Sometimes it gets loose, frayed or otherwise has a poor connection. When I had this problem the wire would make/break contact depending on where the motor was swinging from the torque. I simply ran a secondary ground wire [which is still there after two years...]
Old Mar 1, 2006 | 10:45 PM
DENN_SHAH's Avatar
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
if everything you have been told so far checks out, the fan motor may be dying. next time it does it, open the hood & tap on the fan motor with a screw driver, if it starts running replace the motor.
Old Mar 2, 2006 | 09:21 AM
stitchop's Avatar
Car: 91 firebird
My fan did the same thing when the switch broke, I got a used switch off of a junk car, works right now.
Old Mar 2, 2006 | 05:27 PM
Car: 1982 Z28
Engine: 350 HO
Al right, thank you all, I'll check these things out tomorrow night.
Oh, one thing. Where is the Blower motor? Under the dash pad?
Old Mar 2, 2006 | 09:44 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Your blower motor is mounted on the passeger side of the firewall.Look on the far lbetween the passenger fender and the receiver/dryer.You'll probably find a lot of leaves and pinestraw in there.And don't be surprised if it's home to a small furry 4 legged friend.
Attached Thumbnails Why does my heater fan work 'sometimes?'-8c_12cfimotor.jpg
Old Mar 2, 2006 | 09:55 PM
coolram62's Avatar
Engine: LU5 305 CFI
This isn't an F-Body,obviously,but it gives a better idea of the blower placement than the other pic I posted.It's behind the SPID on the fender.Has 7 to 10 7MM retainer bolts
Old Mar 5, 2006 | 02:54 PM
Car: 1982 Z28
Engine: 350 HO
I like my relatives, but they'll sure impede car progress...
I just took this picture, it's the big black thing on the very left, right?
Can you see the resiistor block in here? ANd, it the ground the black wire that's kind of clipped on?
Old Mar 5, 2006 | 04:12 PM
Car: 1982 Z28
Engine: 350 HO
I think I found the resister block.. It's the rectangular cubic thing above the green clip in my picture, right?
EDIT: I don't have a test light, but I do have a digital multi-meter... What kind of voltage/amps should it be getting on hi?
Old Mar 5, 2006 | 05:44 PM
Car: 1982 Z28
Engine: 350 HO
ok, more info... I've got the relay thing off, and I used a multimeter to test resitance..
It's got prongs in this shape:
1 _
2 _
5 _
3 and 4 are the two verticle ones..
I get no resistance between 5 and 4, and no resistance between 2 and 3.. Per my memory anyway..
Should that be what's going on, or is it blown?
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Leggman1
Aug 6, 2015 04:15 AM
