what kind of transmission mount do i have!?!
Old May 1, 2001 | 10:54 AM
untchbl88's Avatar
i have an 88 firebird 2.8 manual. does anybody have a picture or a description of what the mount looks like, and how to change. by this i mean, how many bolts, what the mount looks like, where i can get it. any help would be greatly appreciated
Old May 1, 2001 | 11:59 AM
86Chicken's Avatar
The mount is on the rear of the transmission attached to the tranny with two bolts. The mount is then attached to the crossmember with one nut. The poly ones look a bit different than the stock ones but they are pretty simple to install.
Lift the car, support the tranny, remove nut from rubber mount, remove X-member bolts(4), remove X-member, remove bolts (2) from mount to tranny. Installation is reverse. Plan about an hour but it should take less depending on how stuck the bolts are.
Get a ES one from Summit, costs less than from a dealer and it works a lot better.
This weekend I have to change mine for the third time. This time I am going to use the ES one.
BTW: The mounts for autos and manuals are the same. After the swap I used my auto mount on the manual and it worked just fine.
Enjoy!!
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
[This message has been edited by 86Chicken (edited May 01, 2001).]
Old May 1, 2001 | 12:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
<font face="Verdana, Arial" size="2">Originally posted by 86Chicken:
BTW: The mounts for autos and manuals are the same. After the swap I used my auto mount on the manual and it worked just fine.</font>
Thanks for the info, Dale! Good to know that the poly -does- work for both.
Old May 1, 2001 | 12:28 PM
86Chicken's Avatar
Actually Tom, I am ASSUMING (we all know what that means ) The mount bolt locations are the same on both STOCK mounts. This weekend I will try to bolt the poly one to my 700R4 (still in garage)to make absolutly sure.
Dale
Old May 1, 2001 | 12:35 PM
untchbl88's Avatar
does anyone know what the cannister looking thing is hanging from my tranny crossmember?
[This message has been edited by untchbl88 (edited May 01, 2001).]
Ovrclck350's Avatar
Here's a pic, and make sure that you torque the mount down properly, or else you'll think that you broke it again, kinda like I did.
Smile, you're in my rearview I'm joking, I have a v6.
Respect My Authoritaw {Cartman Voice}
See pics @ Billy's Firebird
92 Bird 3.1L Auto--Best $750 I ever spent....DRIVE IT LIKE YOU STOLE IT!
Kills:93 Mustang LX (Before Mods),98 or 99 Dodge Stratus (tough one, edged out at 40),92 Camaro RS 305 TBI-Not too fair, his fuel pump went out 2 days later. Nice car, but not running right. 97+ Honda somethin or another...modded....kept at my door the entire way
Close Calls-94 Grand Am 3.1 V6, 92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Best LOUSY Run...17.263 @ 77.79MPH
In a Dog Eat Dog world, I STILL go after tha cat.
Old May 1, 2001 | 12:41 PM
Ovrclck350's Avatar
BTW, I did mine without taking the crossmember off, but it was a biznitch. I took off that little thing that my mount sits on, jacked my tranny up as high as I could, and managed to get everything back right.
Old May 1, 2001 | 02:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh- didn't see that; I didn't yank my crossmember down, either. I jacked the trans up using a wide piece of wood between the jack and trans pan. (I have the automatic trans.) My poly mount goes right to the crossmember, though... it doesn't go to that slab of metal (white arrow points to it) above the crossmember.
Old May 1, 2001 | 04:06 PM
Ovrclck350's Avatar
strange....that pic's of an auto trans and yours didn't have that piece? Is mine just messed up, or am did GM change something?
Old May 1, 2001 | 05:17 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
yea mine looked nothing like that, and my new trans mount is round
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 1, 2001 | 08:46 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
My t-5 mount looked nothing like that either,,.... I had to change it a while back.... Completely different mount... dont know if the auto mount will fit or not....
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old May 2, 2001 | 06:39 AM
untchbl88's Avatar
i have a question, after you changed your mount did you experience any harsh vibrations. right now, i took out the old one and welded a piece of steel in that gap a ran a poly mount. now my car vibrates at high rpms(generally 2000 and up). the vibration, right now, seems to be coming from all over the car, but it also seems to be louder in the car. outside there is no difference in sound the car makes and there are no new noises. if anyone has any clue as to what this might be, or how i can fix it i would appreciate any feedback i can get
[This message has been edited by untchbl88 (edited May 03, 2001).]
Old May 2, 2001 | 02:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think it was a design change of GM. I remember reading somewhere, some time ago, that the center hole in the crossmember would fatigue and crack, leaving the trans mount with nowhere to be bolted. Looks like that extra piece of metal (with the white arrow going to it) might distribute the impact better over the crossmember...?
Next time I'm in a junkyard, I'll have to dive under some cars and check it out. Maybe I can get a "year" comparison going. Actually, now that I think about it, I don't remember my friend's '89 Camaro (the 2.8/2.8 swap) having that piece, either.
I didn't notice any harsh vibrations, but then again, my car vibrates already, so...
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
