Ok, who's V6 didn't get a smog pump from the factory??
Old Sep 2, 2001 | 08:53 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I am almost positive that someone on here has said they don't have one. Plus I have seen an 89 V6 5speed with no smog pump and just a bracket and pulley in it's place. The guys in general tech say ALL cars had them from the factory.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Sep 2, 2001 | 08:57 PM
Bird With NoS's Avatar
Some ppl remove them. For what purpose i dont know. pretty much everyone here has used cars So the precius ovener probly removed it. I kinda remember readin somethin on removin it is good or sumthing.
Old Sep 2, 2001 | 09:02 PM
Engine: LH0 3.1L
Jesus christ, yes i realize that. BUT WHY IS THERE A PULLEY AVAILABLE FOR SOMETHING THAT WASN'T MEANT TO BE REMOVED????!!!!!
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Sep 2, 2001 | 10:47 PM
Kevin S's Avatar
Mine does't have any smog **** what so ever.The OEM CAT did not have any air tubes at all.I replaced the serpentine belt,they gave me one that was to long.I told them I don't have the smog pump.They got a OEM replacement belt with out smog pump.It fit perfect.
I think a lot of it depends on where the car will be sent to be sold.
I have a pully in place where the pump would have been just to keep the belt from rubbing itself after coming off the alt.
The next time you think your perfect,try walking on water!
[This message has been edited by Kevin S (edited September 02, 2001).]
Old Sep 2, 2001 | 11:37 PM
Xenodrgn's Avatar
Nope, I don't... I don't even see a provision for it on my car... I only have AC, Alt, Water, Crank pulleys's, three belts, and no unused grooves... unless I'm missing something...
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Sep 2, 2001 | 11:38 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I was lookin at my friends 89 2.8 and it didnt have a smog pump either i couldnt understand why it just had a pully in its place too. he said it was awlays like that
Old Sep 3, 2001 | 01:06 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i dont have one.
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 3, 2001 | 01:29 AM
Vortex94Z's Avatar
None on my old RS, 2.8 s/ 700R4
1994 Z-28 - LT1, A4, 2.73's, 130,000, red, t-tops, N98 chrome rims, K&N, TPIS Airfoil, enerything else stock
Previously owned: 1989 Camaro RS - V6, 700R4
Old Sep 3, 2001 | 01:35 AM
Camaro_hunter_d's Avatar
well mine does have one but I changed it to a vacuum pump so it does serve some purpose now!.
Old Sep 3, 2001 | 02:39 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Well, my car has the California Emissions, but it doesn't have one, there's a pulley for where it's supposed to go, but thats about it. 2.8 w/ 700r4.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
New Pioneer Head Unit
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Sep 3, 2001 | 02:49 AM
Engine: LH0 3.1L
<font face="Verdana, Arial" size="2">Originally posted by 89V6FBIRD:
</font>
ALL CA GUYS, did you all pass smog with setup????????????
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Sep 3, 2001 | 04:08 AM
FAST RS's Avatar
I would not know cuz mine has one but im sure my freind had to pass his to get his tags.
Old Sep 3, 2001 | 10:44 AM
Nixon1's Avatar
Mine has the smog thing in it.. And it's freaking huge! I've heard that removing it and running the belt without it will free up some horsepower...but I'm not doing anything to my car that isn't street legal, so...I'm guessing pulling this sucker is out of the question. Too bad... I could use all the performance I can get.
1991 RS 3.1 liter auto
All stock except: K&N and 7mm coppercore wires
Old Sep 3, 2001 | 11:23 AM
KED85's Avatar
You MAY loose 1-2 hp with that unit.
I'm not under my hood now. I'll check later.
I have separate belts, not sepintine set up. Mines the 1985 set.
IF ya have it, don't worry, just make sure it spins freely! It is the same effort to spin as an idler arm.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 3, 2001 | 11:43 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Every car is different, although all cars sold in the US should have a smog pump some dont. This is from the prevoiuis owner. Cars sold in Canada were not given smog eqquiptment until latter 80's so that could be why some have the pulley unit instead of smog pumps. In the case of the no air tube for the cat that would be why.
SSC
Old Sep 3, 2001 | 01:47 PM
i pass smog fine..no problems
700r4--&gt;t5 w/ram clutch
See my car Here!
Old Sep 3, 2001 | 02:30 PM
WaynesRS's Avatar
88 rs 2.8 , no smog pump
Old Sep 3, 2001 | 04:04 PM
HIX5000's Avatar
My 88 RS 2.8L standard has one but the 88 SC 2.8L automatic I used to have didn't.
Old Sep 3, 2001 | 08:05 PM
89V6FBIRD's Avatar
I passed, with flying colors. I was amazed at the low numbers to. I'll post them if you guys want them. Have to find them first.
Old Sep 3, 2001 | 09:23 PM
86Chicken's Avatar
In '86 only the 5sp got one. The autos had no smog pump.
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --&gt; Now T5
Great cars aren't bought, they are built
Old Sep 3, 2001 | 09:30 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
I have one on my 83 firebird, it's right under my altinator. I'm getting rid of it soon, it dosen't do anything. Just robs horsepower. oh yeah i have a 5 spd. How can i get serpentine system for my 2.8, or underdrive pullies?
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
http://www.geocities.com/fiream/Robs...l?994187591828
[This message has been edited by fiream (edited September 03, 2001).]
Old Sep 4, 2001 | 02:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My car's like Dale's ('86 2.8 auto), without the smog pump.
Nobody makes power pullies for '82-'86 2.8's; unless you happen to have the same pullies as a V8 of the 82-84 era; which I don't think is possible. The serpentine drive started in '87, and you'd need all the pullies. You'd also need the tensioner... which also mounts the alternator, so you need the smaller version of the alternator. (82-84 already has a small alternator, going to the '87 one would be an "upgrade" in amperage.) You'll also need the idler pulley, which takes the place of the air pump. You'd also need the power steering pump pulley; it might be easier to just take the junkyard p/s pump. And finally, you'll need to change to the donor car's a/c compressor, or, skip your a/c compressor completely, because I don't think you can change pullies at all... even with the tools to disassemble the a/c clutch.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 4, 2001 | 05:59 PM
SlowCamaro88SC's Avatar
88 sport coupe..
no smog pump. no provisions for AIR @ the cat either.
then again.. now it's no cat @ all.
Old Sep 4, 2001 | 08:22 PM
I Cant Drive 55's Avatar
1989 2.8V6 Bone Stock
No Pump Here just a pulley
Old Sep 4, 2001 | 08:26 PM
fiream's Avatar
Engine: 400HP 350
Tom,
I'm just going to take off the pump and belt to the pump, since i have seperate belts i don't need something in it place , like another pulley.
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Sep 5, 2001 | 01:56 AM
AmateurCarGuy's Avatar
88 RS No Smog pump. Its no prob for me yet though.
Old Sep 6, 2001 | 10:38 AM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
According to the GM Parts and Illustration Catalog, no Smog pumps were included in Camaros with automatic transmissions except 82-84 THM200C 3-speed. I don't know about California cars though, since they can always be the exception to the rule. You'll have to find a manual Camaro from the wrecking yard to get the parts. If you need GM part numbers to get from a dealer, I can provide you with them.
[This message has been edited by x55Cam (edited September 06, 2001).]
Old Sep 6, 2001 | 09:49 PM
<font face="Verdana, Arial" size="2">Originally posted by x55Cam:
According to the GM Parts and Illustration Catalog, no Smog pumps were included in Camaros with manual transmissions except 82-84 THM200C 3-speed. I don't know about California cars though, since they can always be the exception to the rule. You'll have to find a manual Camaro from the wrecking yard to get the parts. If you need GM part numbers to get from a dealer, I can provide you with them.</font>
92 5 speed. Have it.
Old Sep 6, 2001 | 10:23 PM
x55Cam's Avatar
Engine: 5.7L
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
</font>
Oops! I made a mistype I edited my post. I meant autos.
92camaroJoe
Jul 29, 2023 07:57 PM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
transaero
Aug 31, 2015 01:14 AM
92camaroJoe
Aug 13, 2015 06:07 AM
