power door lock retrofit?
Old Feb 2, 2002 | 11:12 PM
2vmodular's Avatar
I'm in the process of adding power door locks and remote keyless entry to an 87' firebird. Door lock cylinders keep freezing with the cold weather we've had lately, so finally have motivation to start the project.
I used a dremel to remove the two door lock actuators and associated hardware from two seperate salvage yard firebirds. Had to construct my own wiring harness since wiring was damaged from fire in both vehicles.
Solenoids are now bolted in place, but i'm running into problems with corrosion on the electrical contacts of the actuators. I scrape the whitish corrosion off and the solenoids work for a while, but corrosion re-appears a short while later. Any ideas how to deal with this problem?
Old Feb 3, 2002 | 07:57 AM
gmanuel's Avatar
I have used WD40 to help remove corrison. Then I would coat them with silicon grease.
Old Feb 14, 2011 | 07:42 PM
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
Re: power door lock retrofit?
Di-electric grease.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
