GM TSB for leaking "T-tops"
Old Mar 19, 2002 | 08:33 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
I'm going to try this before replacing t top weather stripping.
CONDITION:
Water leak in roof area between T-Top opening and rear hatch opening. (T-Top vehicles ONLY)
NOTE: This condition may appear to be a leak at the T-Top weatherstrip. It is advised that this repair be performed and tested on T-Top vehicles with leaks in this area BEFORE any other repair is performed.
CAUSE:
Spot weld burn-throughs in rear hatch gutter area between hatch hinge attaching points.
CORRECTION:
Seal weld areas as follows:
1. Open hatch.
2. Compress hatch opening weatherstrip to improve access and apply a thin even coat of 3M Clear Auto Sealer (3M #08551) or equivalent to hatch gutter area between hinges with a small brush. Avoid getting sealer on weatherstrip. Weld locations should be given slightly extra material if possible.
NOTE: Some weld flash may exist near some of the spot welds. This flash is sharp and care should be taken to avoid injury when determining the location of the welds using the fingers.
3. Close hatch.
4. Follow sealer manufacturers recommendation for dry time and test area by running a large amount of water over area. Due to the small size of the burn through holes, the water test should last at least 15 minutes.
:hail:IROC-Z
Old Apr 6, 2002 | 09:06 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Ayone tried this? I did and it fixed mine. I was hoping someone else would benefit from this.
:hail:IROC-Z
Old Apr 6, 2002 | 09:49 PM
Jim's Avatar
Jim
Car: 85 Camaro
I intend to try it as soon as possible
Old Apr 8, 2002 | 11:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ditto, next sunny day i wil be out doing this, if sunny days ever return.......
thanks for the info !
Old Apr 8, 2002 | 11:47 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I will be trying it too. It was raining ALL day today and then I took the car out and it started leaking back there
Old Apr 10, 2002 | 01:59 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok, what stored carry 3M #08551 ??
all we have here are NAPA, Auto Zone and Big R, is there anything else I oculd use to do this with or a GM product i could get at local dealer ? whats this 3m sealer like, what kind of consistancy ? is it like caulk or putty or liquid ? or ?
thanks
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
