1LE fuel tank
Old Mar 26, 2002 | 06:45 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
1LE fuel tank
Will A 1LE (18 gallon ) fuel tank fit in my 89 formula that came with a 15 gallon tank?
Old Mar 26, 2002 | 07:54 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you find an 18 gallon gas tank. Let us know. Take pictures and post part numbers too, a lot of us would think it was cool.
Yes that was sarcasm. It's a myth. Noone has ever produced those 2 simple pieces of info. Another myth is the baffles. All later thirdgens have baffles fuel tanks. Even TBI RS's and 6 poppers. Still around 15.5 gallons w/ the electric pump in it.
Old Mar 27, 2002 | 01:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
For some reason I have a 12 gallon tank in my car.
Gas Gauge works perfect, when it is on E, it is about to run out of gas.
I once had the car run out of gas at the shop when they were tuning my rebuilt carb, they put in one gallon, and I drove to the gas station afterwards and put in almost 12 gallons and it was overflowing. Tank is not dented.
Anyone else have a tiny tank in their 3rd gen?
Old Mar 27, 2002 | 02:30 AM
Jza's Avatar
Jza
Ed: It's true, all thirdgen gas tanks have the metal baffles. But there's a plastic bowl inside the tank that's only on the higher trim-level cars until 90 or 91, then from there to 92 all thirgens had the larger bowl. The bowl has higher sides that helped prevent fuel starvation on hard cornering. And I do have pics of that. The crappy version had a bowl about 1 to 1 1/2 inches high, while the better version had 4 or 5 inch high walls with only a slot cut out on the front for the sender assembly to slide down into the bowl.
Here's the crap version (this one out of an 89RS):
And here's the version found in Z28s and all 90-92 models (this one out of a 91RS):
Old Mar 27, 2002 | 02:34 AM
Jza's Avatar
Jza
Zepher, the only thing I can think of is that your sender assembly is bent or somehow different so that the feed is sitting higher than it should and not picking up the last gallon or so that it should. I seriously doubt you actually have a smaller tank.
Old Mar 27, 2002 | 07:20 AM
Zepher's Avatar
One day when I have the tank off the car I am going to measure the exact fluid capacity.
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
