Which is better, supercharging or turbo charging??
Old Apr 11, 2002 | 12:41 PM
grafx's Avatar
Car: 91 Camaro RS
Transmission: Pro-Built Automatic/Vigilante 2800
I'm just curious which one is the better choice as far as both performance and reliability. Is it possable to install either one and still keep the car smog legal? I see pics of all your guys engines and I don't see how you can fit all those extra components under the hood and still have room for smog equipment.
Old Apr 11, 2002 | 03:17 PM
a73camaro's Avatar
Like anything with a car, there are ALWAYS compromises!!
I personally like turbos because wasted power out the exhaust can be utilized to make power at the crankshaft.
Old Apr 11, 2002 | 05:26 PM
grafx's Avatar
Car: 91 Camaro RS
Yeah but is it possable to run either one and still have it smog legal??
Old Apr 12, 2002 | 10:03 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Don't get me wrong because I have built both turbo and supercharged cars. But, with turbocharging and the fact that there is not currently available a thirdgen turbo "bolt in kit" let alone one that has been emmissions tested, makes it very hard. unless you can not only fabricate your own turbo kit (as many here have), retain all emmissions equipment, and pass the visual, sniffer (probably the easiest part), and give a good arguement to the smog referee you will be sent to, to get certified you could screw yourself. the good news is that companies like procharger and vortech not only have "bolt in kits" for thirdgens, but the have them in verying degrees of smog-legal, and also offer the availability of "bigger" head units that can produce enough boost to turn $20,000 engines to confetti.
Falcon50
Aug 22, 2020 03:26 PM
bjpotter
Oct 4, 2015 07:48 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
