Engine
Car: 1986 Z28
Engine: 406
Axle/Gears: 9-inch w/ 3.50 posi
Engine
Looking to buy high performance 383 or 406 short block or complete does not matter. Let me know what u have. PM me with info.
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
hi there
hi i have a great short block for you, it is a 1970 400 2 bolt block, +30; so it is a 406 the mains are studded, the rods are gm pink 5.7 rods, with arp 2000 bolts, the cam is a retro fit roller cam, and lifters, the pistons are speed pro forged and the rings are file fit for nos or boost. i built the engine 2 years ago and only used it for 1 year it has 3200 miles on it and would like to sell it 2000$ i have about 4800 in to it with parts, machine work and assembly.
Car: 1987 Iroc-z Convertible
I have a fresh 406 with stock crank, rods and speed pro hyper pistons, mellings high volume pump and milodon pan. 0 miles also Lunati bm2 cam .480/.480 I would do $1000 which is $200 less than the prep work so it is like getting bearings, rings, pistons, oil pan and pump, and cam free. let me know if you are interested.
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Got a new 4 bolt main 350, balanced & blueprinted with the 400 crank.
Looking for $2000, + shipping from TX. PM if interested.
84z96L31vortec
Aug 20, 2017 12:16 AM
