9 Bolt Yoke or Complete Rear End
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
The yoke on my 9 bolt rear end is bad, and since there's no new ones/aftermarket I'm trying to find a used yoke. But, if someone has a complete 9 bolt rear end they need to get rid of, that would be an option too.
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: 9 Bolt Yoke or Complete Rear End
I have everything minus the center section and the housing has been POR15ed. Also have a set of 12" PBRs with slotted rotors and braided stainless lines
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
I have a complete 9 bolt, 3:08 non posi drum 72,000 miles -just the complete rear end, no brake parts Removed to install posi rear end that was together already. $100 pick up only. Located in Buffalo, NY area.
Car: 1991 Camaro rs
Transmission: WCT5 Rebuilt by Astro
Axle/Gears: Borg Warner posi disc 3.27
i have a 9 bolt posi, 3.23 gears complete with disc brakes and the housing lines. removed from running 86 IROC auto with strong 400 was working perfectly. $300 frt on you. Located in Memphis, tn. 38122
Car: '85 TA
Engine: 350 turbo
I ended up finding a yoke . Thanks everyone for the offers.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
