Need PWR Antenna cable
Old Nov 1, 2008 | 09:04 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I'm in need of a power antenna cable for a 88 GTA. It screws to the pwr antenna itself and plugs into the back of the radio. I'm told the style changed in 89, so I need to stick with a replacement from an 88 or older. Thanks!
Old Nov 1, 2008 | 09:18 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Need PWR Antenna cable
PM sent. I'll get some pics tomorrow...
Old Nov 1, 2008 | 10:06 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
PM returned, thanks!
Old Nov 3, 2008 | 11:51 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
I should have some! They run $5.00 plus shipping and handling. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas R. ***
(805) 522-2539
www.houseofcamaro.com
Old Nov 3, 2008 | 03:46 PM
BlueIroc-Z's Avatar
Just packed it up, and I'm heading out right now to mail it. Should be there in a couple days. Thanks again!
Old Nov 14, 2008 | 01:44 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Received and installed. After a little work with the multimeter and solder, everything is working as it should! WooHoo! Thanks again!
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
