[Sold] Autoprom, ECU's, FI intakes & parts
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Everything OBO, doing an lt1/t56 swap and my garage is running out of room!
$225 LT1 Intake converted over to run on SBC, includes remote thermostat and hoses, but no fuel lines. It has been ported to a 58mm TB and 1205 intake gasket. Ran for 15k miles w/o any issues. Extra material welded on cover EGR ports on stock heads. SOLD
$125 TPI Intake, fuel rails, and Throttle body. Polished top, started on corvette runners and dist. cover, but lost interest. Buy injectors and an ecu with it and I’ll throw in a wiring harness and whatever other sensors I have around. SOLD
Best offer, 2x GM Map sensors, SOLD
$130 58mm BBK throttle body for an ’88 TPI SOLD
$35 LS1 injectors
$120 30lb SVO Red top injectors SOLD
$40 Gutted TPI MAF Worked good when pulled, switched to SD.
$30 165 ECU with 88 350 chip SOLD
$40 730 ECU with 350 chip SOLD
$40 730 ECU with 305 chip SOLD
$210 USB AutoProm with a/d connector, but no chips. SOLD
$25 GP1 package, chips, zif’s and adapter, I have 2. SOLD
$35 LS1 injectors
Re: Autoprom, ECU's, FI intakes & parts
PM sent
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I'm interested in the 730 ECM with AUJP chip.
Car: 93 Z28
Engine: LT1 w/ 727ecm, $59, N* coil packs
Transmission: 6 gear
Axle/Gears: 3.70
UPDATED LIST
$225 LT1 Intake converted over to run on SBC, includes remote thermostat and hoses, but no fuel lines. It has been ported to a 58mm TB and 1205 intake gasket. Ran for 15k miles w/o any issues. Extra material welded on to cover EGR ports on stock heads.
$200 USB AutoProm with a/d connector, but no chips.
$25 GP1 package, chips, zif’s and adapter, one left.
$35 LS1 injectors
$125 TPI Intake, fuel rails, and Throttle body. PENDING
Best offer, 2x GM Map sensors, PENDING
$120 30lb SVO Red top injectors PENDING
$40 730 ECU with 350 chip PENDING
$35 LS1 injectors
Axle/Gears: 3.70
Everything is sold or pending except the MAF and LS1 injectors.
