'96 LT1 Parts For Sale
Stock Length Taylor 8MM Spark Plug Wires - $6 each (I have 6 left)
Taylor Coil Wire - $10
'96-'97 ONLY B-Body-ONLY Crank Hub - $35
Balancer - $30
'93 A/C Lines - $45 (compressor is sold)
F-Body Accessory Bracket - $50
'93 Alternator - $70
Motor Mounts & Frame Mounts - $60 I will break the set apart
PICTURES UPON REQUEST
Still have these other parts from my old motors.
Make me an offer if my prices are too steep. I'm open to offers. Prices do not include shipping or Paypal issues. Though I always take shipping pricing into consideration. Just PM me and we can work it out, I'm sure. Or email.
Email = hector moore 5 2 at hotmail dot com (delete all the spaces, obviously)
Prices below do NOT include shipping...
Lifter Spider Holder - $35
Opti Harness - $20
Flexplate - $35
Oil Pan Rails - $15
Water Pump Drive - $25
Throttle Cable Bracket - $30
Valve Covers - $35
'93 o2 Sensors - $25
F-Body Starter - $60
PCV Tube (needs new rubber hose) - $25
Pair of OBDII Knock Sensors - $30
F-Body Idler / Tensioner Pulley - $25
B-Body Idler / Tensioner Pulley - $25
Vented Opti 150k Miles - $45
Oil Pump Driveshaft - $10
Rear Main Seal Holder Plate - $20
EGR Solenoid w/ Hoses - $20
EGR Diaphragm - $35
EVAP Solenoid - $25
MAP Sensor - $10
Windage Tray - $25
'95 F-Body Pistons & Rods 70k Miles - $65
IAC Solenoid - $35
Oil Pressure Sensor Elbow - $30
B-Body Oil Pressure Switch - $20
Stock Timing Set - $40
B-Body Offset Oil Filter Adapter with Cooler Ports - $50
T56 Slave Cylinder - $10
Stock Hardened Pushrods - $30
EGR Hard Piping That Goes Under Motor - $35
B-Body Accessory Bracket - $45
'96 B-Body Cam - $40
B-Body Water Pump - $50
Head Temp Sensor - $13
Oil Pan Bolts - $15
Throttle Position Sensor - $10
AIR Pump w/ Bracket - $40
L99 Cam - $35
Throttle Body - $40
Crankshaft - $100
Crankshaft That Needs Turning - $45
Ugly But Nice Crankshaft (.030 under) - $60
Lifters, Spider, Dogbones - $85
Opti Vent Tubing - $40
EGR Parts GALORE - $Varies
Oil Level Sensor - $25
'93 Oil Dipstick & Tube - $35
Crank Position Sensor - $30
Crank Position Cog - $25
I CAN SHIP VIA FEDEX GROUND - NOT INCLUDED. MAKE OFFER. OBO.
Balancer - $30
Opti Harness - $20
Flexplate - $35
Oil Pan Rails - $15
Valve Covers - $35
EGR Diaphragm - $35
EVAP Solenoid - $25
MAP Sensor - $10
Windage Tray - $25
IAC Solenoid - $35
Oil Pan Bolts - $15
L99 Cam - $35
Throttle Body - $40
Crankshaft - $100
Car: 2000 astro
Engine: 4.3
Transmission: A4
Re: '96 LT1 Parts For Sale
do you happen to have spark plug wires? i want to see if the lt1 style will fit my vortec distributor on my 2000 astro without having to go buy a new set of plug wires.
Car: 1966 El Camino Custom
Transmission: 200R4
Any chance you have an LT1 flywheel for a T56?
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
93 throttle body and intake cable bracket? Will buy asap if you have it.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
i need just the EGR soleniod, no hoses, i can give you $15 shipped... they cost $25 new
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
$160 total? done.
pm me your contact and paypal info and i'll get it to you tomorrow or the next.
Engine: 350tpi
Transmission: 700r
i just read through your whole ad, and noticed you have three cranks for sale.
i was interested in the eagle 383 crank.
is that the one you quoted the price for?
1992 Trans Am
Aug 8, 2015 08:16 PM
