Trade: Edelbrock STB for your used 24lb Injectors
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Just like the title says. I'm trying to trade some stuff for a set of 24 or 32lb injectors. I have an edelbrock STB, aluminum spare, a stock T-5 shifter, stock serpentine pulleys from the crank, water pump and alternator. I also have a TPI setup w fuel rails, injectors and the cold start injector. The only problem w the base manifold is that i was attempting to drill it out to fit prior to 86 heads so it is a little cut up but the rest of the package is good to go.
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
Re: Trade: Edelbrock STB for your used 24lb Injectors
I have a set of injectors from a 87 350, I believe they are 24's.. Put me inline for the stb...thanks
Car: 1966 El Camino Custom
Transmission: 200R4
Got a nice set of Accels that have just been serviced. Willing to trade.
Want a title? Post!
Car: 88 GTA
Engine: 305 tpi
Transmission: WC t5
Axle/Gears: 3.27s posi
I'll trade you a pair of lucas 24lb for the stb. Throw me in line.
toronto formula
Sep 10, 2015 07:31 AM
