[NC] Manual S10 Steering Box w/ Fbody Arm
Old Jan 19, 2010 | 09:41 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Title says it all. I have a manual power steering box from a s10 truck. It is the correct 4 bolt top, and already has the Fbody pitman arm installed. New grease inside the box. I know it works b.c i had it bolted in my car for a little while. Dont have a picture but it is cleaned up and freshly painted.
$125 shipped anywhere in the US.
Old Jan 23, 2010 | 11:58 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Manual S10 Steering Box w/ Fbody Arm
pm sent
Old Jan 23, 2010 | 09:06 PM
heff17's Avatar
Car: 89 Camaro
Here is a pic, its a little dusty from sanding a fender in the shop.
Attached Thumbnails Manual S10 Steering Box w/ Fbody Arm-img_0809.jpg
Old Jan 25, 2010 | 05:28 PM
heff17's Avatar
Car: 89 Camaro
still for sale!
Old Jan 28, 2010 | 09:38 PM
heff17's Avatar
Car: 89 Camaro
Normally people jump all over these things, whats wrong with mine?
Its ready to bolt in and run,
Bump!
Old Jan 30, 2010 | 08:43 PM
shelby7099's Avatar
Car: 1984 Camaro Z28
Engine: 350ci
Axle/Gears: 3.31 non posi = no traction
I am interested. I am running a ps box right now, looped without the pump. So it is a direct bolt in, right?
Old Jan 30, 2010 | 09:02 PM
heff17's Avatar
Car: 89 Camaro
Yes, it is a direct bolt in for our cars. I was running it in my camaro for a couple of months.
Old Jan 30, 2010 | 09:46 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
what is the difference between having power steering and no power steering? Is it harder to turn the steering wheel without?
Old Jan 31, 2010 | 08:31 AM
heff17's Avatar
Car: 89 Camaro
If your running power steering with the steering pump hooked up it will be easier to turn the steering wheel. however if your power steering pump isnt hooked up like shelby7099 replacing the stock power steering box with a non-power steering box will make the steering wheel alot easier to turn. because it has a different gearing inside the box.
Old Jan 31, 2010 | 01:10 PM
HCR13's Avatar
Car: 1987 Trans Am
so is there a steering (not motor) advantage to using manual steering? Would this be a good idea in a daily driver?
Old Jan 31, 2010 | 01:19 PM
Project-RS's Avatar
i just did a manual swap and mine turns easy consider no power steering. the advantage is less weight. (hoses, brackets, pump, lines). mine will be a weekend car because the motor setup im doing. it does free up extra power because your motor will no longer need to use the extra force needed to operate the pump pulley. if your not used to driving a manual steering car. you will have to get used to it.
Old Jan 31, 2010 | 02:58 PM
RITTER's Avatar
Car: 1983 Buick Regal
Axle/Gears: 4.11
I am looking for a manual steering box, but I can't understand why people want so much for a used one. I work at NAPA and we sell a completely remanufactured box for $150, just doesn't seem logical to pay $100 for a used one when I could get one for $50 more that has been rebuilt.
Not trying to start a fight but just wondering why?
Old Jan 31, 2010 | 03:55 PM
Project-RS's Avatar
you sure its the right one for 150? autozone has them for over 200. mid 80's 4 cyl s-10 with the 4 bolt design. i also like how i go to the napa site and they dont even give me a price for the steering box.
Old Jan 31, 2010 | 08:22 PM
heff17's Avatar
Car: 89 Camaro
Lots of people like the steering feel with the non power steering box. As for the price. I just listed it for what i saw most of them selling for on this board.
Old Feb 1, 2010 | 03:03 PM
heff17's Avatar
Car: 89 Camaro
Still for sale...
Old Feb 1, 2010 | 05:51 PM
HCR13's Avatar
Car: 1987 Trans Am
if you still have this by the time I get some extra $$, I'll probably get it...but until then, BUMP!
Old Feb 1, 2010 | 06:44 PM
heff17's Avatar
Car: 89 Camaro
sale is pending...
Old Feb 2, 2010 | 06:29 PM
heff17's Avatar
Car: 89 Camaro
Sold
Hotrodboba400
Dec 10, 2019 07:07 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
