vortec heads/ 350 block and random tpi parts
Old Jun 28, 2010 | 10:52 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
96 T/A rear sway bar, ill get a measurement, but its stock $10 plus shipping
rear disc brakes from 96 T/A= calipers w/old pads, lines & rotors, theyll work for a few more thousand miles $20 plus shipping i had them for a swap but i got a rear including LS1 brakes... SOLD!
b2L/l98 shortblock from a 90 formula has a few rusted rings so im discarding it and getting a different one has no cam lifters timing set just a block with the pistons rods and crank installed im junking it if no one wants it, it will get you a core charge come get it PLEASE im gonna have to scrap it and get 10$... SOLD! went to the Junk yard and got $50 for it
set of complete w/ rockers, vortec heads 062 i cracked the valve cover lip removing them Atilla says to fix with jb weld, i just spent a little more money and got a new set i just want to get a little money back 225$ shipped or pick up for $125 i can deliver within a reasonable distance NY NJ PA area im in zipcode 18428 mapquest it and see how close you are to me... pics are in this thread https://www.thirdgen.org/forums/engi...block-zz4.html ill throw in brand new package of JB weld, my manley race flow valves(1.94/1.5) new seals and locks/ retainers so youll just need new springs and valve guides done and everything will be new $275 shipped SOLD!!!
24# 96 LT1 injectors bought for TPI swap same deal selling for 383 but will keep if they dont sell $35 shipped
TPI throttle and TV cables w/ bracket SOLD!!!
TPI lower AC line with sensor 20$ shipped
bnip 6an x6' braided stainless fuel line 20$ shipped unless shipping is more then 10 bucks
l98 water pump 5$ plus shipping just pay me 5$ to box it and take it to the ups store(25 miles from me) and pay the shipping(its heavy), it works fine i wire brushed it and painted it black looks nice if your in a pickle and need one for now itll work
99 vortec 5.7L truck cam think its like 420 430 lift not sure but it would be a good 305 upgrade for cheap 30$ shipped
iroc air intake 35$ shipped
make an offer i only need a few little odds and ends from the junkyard to complete my project
Last edited by FlippindaBird; Feb 11, 2011 at 12:02 PM. Reason: added stuff/ lowered prices
Old Jul 4, 2010 | 02:10 PM
Re: 350 block and random tpi parts
ttt
Old Jul 6, 2010 | 06:53 PM
ttt
Old Jul 12, 2010 | 09:06 PM
ttt
Old Jul 13, 2010 | 12:54 AM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
pm sent
Old Jul 13, 2010 | 10:15 PM
some pics of the block if you want any specific pics let me know
Attached Thumbnails vortec heads/ 350 block and random tpi parts-engine-block-003.jpg   vortec heads/ 350 block and random tpi parts-engine-block-005.jpg   vortec heads/ 350 block and random tpi parts-engine-block-001.jpg
Old Jul 13, 2010 | 10:22 PM
added stuff at the top
Old Jul 14, 2010 | 02:15 AM
ogg__666's Avatar
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
TPI throttle and TV cables $35 plus shipping would you take 25$ + shipping or 30$ with the brackit on the side of the tpi ?
Old Jul 14, 2010 | 08:41 AM
sorry dot have the bracket and i would like to get 35, im actualy getting another tpi setup so i can use these if i dont make what i want they are 45 plus shipping brand new
Old Jul 15, 2010 | 07:12 AM
TTY
Old Jul 17, 2010 | 07:33 PM
ttt
Old Jul 20, 2010 | 08:09 AM
ttt
Old Jul 27, 2010 | 07:58 PM
new items and a pic
Attached Thumbnails vortec heads/ 350 block and random tpi parts-001-copy.jpg
Old Jul 31, 2010 | 11:52 PM
ttt
Old Aug 6, 2010 | 05:19 PM
$125 for the block get it now if it sits here much longer the price goes back up or i assemble it and sell it that way i really just wanna get it out of my house, its in the laundry room and in the way
Old Aug 6, 2010 | 05:27 PM
more stuff new prices
Old Aug 8, 2010 | 01:38 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Hey I'm interested in the block, can you type the casting numbers? I can't see it that well in the picture. May be interested in the L98 block, not sure which one yet.
I might be interested in the hyd roller lifter stuff too, what hyd roller cams do you have?
I'm also interested in the L98 vette heads as well, my current stock 87+ non-vortec intake should bolt up to it...right? What are the casting numbers on those heads?? I'll definitely take them off your hands lol
Better yet I'm interested in a BUNCH of stuff you have there, perhaps we can talk more via pm, I'm getting a bit of money on the 15th to redo a motor that desperately needs some work, or get another.
Old Aug 9, 2010 | 10:29 AM
397010
Old Aug 9, 2010 | 03:02 PM
pm returned
Old Aug 13, 2010 | 11:16 AM
still for sale need cash
Old Aug 16, 2010 | 08:07 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
Originally Posted by FlippindaBird
TPI throttle and TV cables w/ bracket $40 shipped
Would you sell just the Bracket that mounts to the upper plenum that holds the throttle cable and TV dent cabel, it bolts on the drivers side with 3 bolts? If so shipping to Ontario Canada, postal code L3C2R8
Old Aug 17, 2010 | 05:55 PM
to canada... 30$ shipped sorry but last time i shipped something to canada it was horrible 20$ for 1.5 lbs
Old Aug 17, 2010 | 06:11 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
hey im looking for the fuel lines off the rail for a serpentine setup even the rubber parts, and im also in need of that air intake if its still up for grabs
Old Aug 18, 2010 | 08:16 AM
you can def get the air intake the fuel lines however i do not have, unfortunately ive never gotten ahold of a serpentine setup im still running vbelts paypal rongsays@aol.com for the air intake ill get it out friday am as im on my way to work now
Old Aug 18, 2010 | 08:45 AM
vortec heads for $275 plus shipping added see pics in this thread https://www.thirdgen.org/forums/engi...block-zz4.html
Old Aug 18, 2010 | 11:34 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Ok ill need the air cleaner and for the fuel line I tink ill just have to go AN fittings on it, there's no reason to route it to the front of the block I can but go off the side
Old Aug 20, 2010 | 09:24 AM
sounds good soon as the paypal confirms payment itll be shipped
Old Aug 20, 2010 | 12:30 PM
jesredvette's Avatar
Want a title? Post!
I'll take the throttle body . PM sent.
Old Aug 20, 2010 | 07:45 PM
going to UPS tuesday am if i have the paypal ( rongsays@aol.com ) payment for the air cleaner by then i will ship it as well as anything that anyone else wants, trying to get up the rest of the money to finish my project and im real close
Old Aug 24, 2010 | 11:04 AM
ttt
Old Aug 27, 2010 | 11:09 AM
tt
Old Aug 31, 2010 | 07:12 PM
iroc the 88's Avatar
Car: 1988 camaro iroc z
Engine: 5.7 350
Hey do you still have that tpi engine harness. Im very interested in it.
Old Aug 31, 2010 | 07:20 PM
yes please buy it!!!
Old Sep 12, 2010 | 05:21 PM
ttt
Old Oct 10, 2010 | 09:55 AM
Re: vortec heads/ 350 block and random tpi parts
ttt
Old Oct 15, 2010 | 11:34 AM
lowered prices everything must be gone before i move in february
Old Oct 15, 2010 | 12:32 PM
3GEN90's Avatar
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
PM Sent
Old Oct 15, 2010 | 06:22 PM
pm returned
Old Oct 27, 2010 | 08:34 AM
ttt
Old Oct 27, 2010 | 01:07 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Still need a 350 block? It's a 638 roller block
Old Oct 29, 2010 | 10:11 AM
would have taken it a few months ago... wont need one till next year now, but i may just buy one thats already clearanced for a stroker crank, and put together a 383 myself, thanks anyway though
Old Feb 1, 2011 | 12:32 PM
edited OP sold some, added some
Old Feb 7, 2011 | 04:31 PM
ttt
Old Feb 8, 2011 | 10:10 AM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
pm sent...
Fast355
Dec 2, 2016 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
