90-92 Auto Camaro Shifter Plate
Old Sep 25, 2010 | 09:34 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Hey guys. The rubber strap in the shifter plate of my '92 Camaro just broke. Does anyone have a shifter plate (auto) they need to get rid of? I'm looking for one as close to mint condition as possible.
I also need a little block-off plate for the dash, that goes under the headlight switch. I believe it's where the fog light switch would be, if I had fog lights.
Let me know if you've got anything. Thank you.
Old Sep 26, 2010 | 11:34 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 90-92 Auto Camaro Shifter Plate
Sorry, no shift plate, but I've got the other piece with all mounting studs intact. You want a pic or anything?
Old Sep 26, 2010 | 02:07 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Why dont you just replace the plastic strip?Ive got a box full of them
Old Sep 26, 2010 | 02:32 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
henryd3: Yeah a pic would be nice. Just to make sure we're talking about the same thing here. You can send it to SDSanchez88@Gmail.com if that's easier. Thank you.
my82roc: I believe the piece is different in the 90-92 models. But where did you get that box?
Old Sep 26, 2010 | 07:19 PM
my82roc's Avatar
Your talking about the rippled piece with the hole that the shift lever goes thru...correct?Only difference for 90-92 is that is has an extra plastic piece mounted on it around the hole.I gut these shift plates all the time at junkyards and have lots of parts to put them back together
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
NBrehm
Aug 25, 2015 11:49 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
