[KS] WTB: 87 IROC upper oil pressure sender fitting
Old Oct 11, 2010 | 01:33 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
This is the fitting that threads into the top of the block behind the intake manifold. I've tried hardware store stuff, but would like to have a factory part like this. The threads on this one are worn and leak. Please let me know if you have one or two of them available.
Also looking for a 3pt STB if the price is right.
Old Oct 11, 2010 | 09:36 PM
88Cvert's Avatar
Car: ,89 iroc z
Engine: 350 tpi
Transmission: ,700r4
Axle/Gears: 3;27 9 bolt
Re: WTB: 87 IROC upper oil pressure sender fitting
im pretty sure i have at least one of those fittings ,ill have to check .and i have a set of hood struts and possibly a headlight **** .ill pm you tomorrow if i find the stuff.
Old Oct 12, 2010 | 05:01 PM
thewizard's Avatar
Sounds good. I appreciate it.
Old Oct 14, 2010 | 03:27 PM
thewizard's Avatar
ttt
Old Oct 17, 2010 | 10:21 PM
thewizard's Avatar
ttt
Old Oct 18, 2010 | 12:29 AM
88Cvert's Avatar
Car: ,89 iroc z
Engine: 350 tpi
i didnt forget ya..still gota find it .found the headlight **** though ..
Old Oct 18, 2010 | 12:51 PM
thewizard's Avatar
Excellent. I did a couple WOT blasts the other day and my hardware store fittings started leaking.
db057
Aug 22, 2015 08:17 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
ChevyZ71
Aug 13, 2015 07:30 AM
matthew911
Aug 12, 2015 09:38 AM
