WANTED FOR A 91
Old Mar 29, 2011 | 11:14 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
WANTED FOR A 91
i need the plastic bezel that snaps over the fog light switch on a 91. or even a delete plate will work also. its located to the left of the steering wheel
Old Mar 29, 2011 | 01:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: WANTED FOR A 91
I'm not trying to be a PITA here, but good luck!
It took me 4+ years to locate one. Only the 1990, 91, 92 cars had that different cluster setup, so it makes them hard to find.
I took my regular delete plate, and cut a hole in it for the fog light switch. Not easy, the plastic is thick there. I drilled, dremel'd, scraped, etc until I had it. I finally came across a real plate about 2 months ago.
So, might try that as an option until you luck across one. I just wanted to tell you not to hold your breath, it might take a while to locate. Good Luck!
Old Mar 29, 2011 | 01:55 PM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
Re: WANTED FOR A 91
ill take a delete plate also. i mounted my NOS switch in there. so ill take either
Old Mar 29, 2011 | 04:32 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: WANTED FOR A 91
Hi' I've got both a delete plate and one that someone already cut out a hole in. PM or email me your email address for pics or other info
Old May 30, 2011 | 08:22 AM
Davejs's Avatar
Re: WANTED FOR A 91
I may have a delete plate, still looking?
Old May 30, 2011 | 09:03 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
Re: WANTED FOR A 91
i got 1...thanks
Old Jun 4, 2011 | 03:50 AM
rock861261's Avatar
Re: WANTED FOR A 91
Anybody else looking pm an offer
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86White_T/A305
Aug 17, 2015 12:16 AM
