[WA] WTS Arizona Speed and Marine 58MM TB $220 SHIPPED
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Have a Like new Arizona Speed and Marine 58 mm TB (SOLD)
Top of the line. for less then Half price. shipped.
will post pic. Has the trick parts on it.
this came in with some Super charger parts and not going to use it.
so it's up for sale.
Ill wave Paypal Fee's NOTE: PIC was taken a few min ago. New batt in cam. did not reset date. oops
another shot
ALSO HAVE air to water Cooler. comes with water tanks.Pump and some lines
$350 shipped.. this is set up to bolt to pasngr side SBC
ALSO HAVE
fluid Damp for 383/400+ cid SBC extrl Bal
sfi cert no dings. only used on 1 eng
come with Matching flex plate 168 tooth Hughes sfi cert
$250 for the set shipped (less then half price)
parts would pass for new. just dusty
another shot
ALSO HAVE
Re: WTS Arizona Speed and Marine 58MM TB $220 SHIPPED
any idea what years the linkage on the TB will work for (the early and late cables are different, some brands use different pn's, come with multiple brackets...)? Part number (not sure if this will help, they no longer list it on their site)?
Do you have a PN on the intercooler? inlet, outlet and overall dimensions?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
85-88 throttle linkage !
PM Reply. sent TB is sold.
posting a link that will have more photos.
hope it helps. will post more Pics today
it's still on there site. ($425+) think it was under BBC parts
took a look last night. before i posted
will be listing a all ACCEL PARTS Super Ram with NOS Fogger(ACCEL BASE ALSO)
NO Butchering has been done to it. Port match only By (Lingenfelters shop)
can remove NOS set up and close with 1/4 pipe Plugs (on sides of top air box)if you want.
this set up ran 10.50's. on Lingenfelters 50 state smog ligt 383 (stage 5 My Car)
it will come with a full gasket set (Gasket set.new from the last 2 years)
all you do is Bolt it on!
https://www.thirdgen.org/forums/engi...ech-v-1-t.html
getting a few guys asking if its all accel...Yes..Yes it is. this is 9 years Of Dust. just before i pulled the Eng. pulled a NOS Hard line to check Jet size.. this set up was from the Mid 90's
look below EGR Block off plate. see Accel 100% also note.. runners not all Cut Up!
your TB Should be at your door today.
Jeff
Jeff
Fast355
Dec 2, 2016 06:33 PM
