Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
TPIS Minirams are finally selling (cheap?) on ebay
Old 03-29-2015, 10:14 PM
  #201
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Re: TPIS Minirams are finally selling (cheap?) on ebay
And yet they aren't willing to come off their price points.
Old 03-30-2015, 11:39 AM
  #202
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Probably because they paid too much initially.
-- Joe
Old 04-26-2015, 04:33 PM
  #203
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Another
http://www.ebay.com/itm/291444015682
Old 04-26-2015, 08:48 PM
  #204
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Originally Posted by B4Ctom1
$900+$50 shipping
Old 05-12-2015, 11:35 AM
  #205
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Accel Super Ram new old stock
http://www.ebay.com/itm/371324585808
Old 05-12-2015, 03:03 PM
  #206
Tibo's Avatar
Car: 1991 Z28 Vert
Long as a bidding war doesn't start that could be a good deal
Old 05-17-2015, 08:58 PM
  #207
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Best price in years $700 buy it now with a throttle body and rails. Doesn't say injectors, but I see them in the pics.
http://www.ebay.com/itm/191581819664
1205 size gaskets
be gone by morning?
Old 07-30-2015, 12:26 PM
  #208
B4Ctom1's Avatar
Car: 1992 B4C 1LE
This miniram with everything but the TB and having the 1206 gasket ports and at only $650 won't last the day http://www.ebay.com/itm/252041582689
Old 07-31-2015, 08:32 PM
  #209
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Good buy bummer for me!!
Old 08-11-2015, 02:36 PM
  #210
B4Ctom1's Avatar
Car: 1992 B4C 1LE
$800 http://www.ebay.com/itm/231649258530
$600 http://www.ebay.com/itm/121727571817
Old 08-12-2015, 05:28 AM
  #211
anesthes's Avatar
In another year or so these things will be $500 or less.
They are a bitch to tune. Plenum is too small, fuel distribution sucks, and the 1205 version doesn't have enough casting to cover 1206 heads.
-- Joe
Old 08-12-2015, 09:45 AM
  #212
B4Ctom1's Avatar
Car: 1992 B4C 1LE
The Holley Stealth ram or a single plane are probably still the ideal setup for our rides?
Old 08-12-2015, 09:57 AM
  #213
anesthes's Avatar
Singleplane with the right size plenum (6" plus intake), and a good 4bbl or a high flow elbow.
The HSR is a compromise. You get a good plenum, but tight angles on the airflow. I have an HSR on my turbo car but I figure whatever loss I get due to the intake I can make up with boost.
The Miniram is impossible to tune. You always get lean or rich cyls. People don't realize that the LT1 had a sequential ECM with a per-cylinder fuel trim. You can't do that with an 80's delco ECM.
-- Joe
Old 08-12-2015, 12:37 PM
  #214
B4Ctom1's Avatar
Car: 1992 B4C 1LE
How about tuning with something like a Bigstuff 3?
Old 08-12-2015, 01:28 PM
  #215
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
The TPIS Mini Ram has fuel reversion problems.It sucks fuel up into the back of the plenum.So your rear cylinders will always run rich.and there's nothing you can do about it no matter how much tuning you do.Plus you trade a boat load of torque for horsepower.
Old 08-12-2015, 05:48 PM
  #216
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Thanks, good to know. From both of you.
Old 08-12-2015, 06:04 PM
  #217
CORV3TT3's Avatar
Interesting post- I had always wondered why I didn't see as many of the TPIS units as I saw HSRs, but hadn't heard anyone talk about the challenges to tuning them.
I wonder if the 24x system would be a viable solution to address that.
Old 08-12-2015, 09:39 PM
  #218
anesthes's Avatar
Can you do a per cylinder injector trim?
The only stock stuff I have experience with is the older DELCO (thirdgen, C4) and LT1 stuff. I've not touched any of the LSx stuff. And all I use is aftermarket now.
Cylinder injector trim is still a band aid for a defective manifold design.
-- Joe
Old 08-13-2015, 01:25 AM
  #219
Tibo's Avatar
Car: 1991 Z28 Vert
I think it's more so the price the the mini ram was sold at vs the price of the stealth ram or single plane. Lower price units usually prevail.
Old 10-12-2015, 06:21 PM
  #220
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Another
http://www.ebay.com/itm/371460274032
Old 10-16-2015, 10:22 AM
  #221
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Another http://www.ebay.com/itm/381439132423
Old 05-27-2016, 08:58 AM
  #222
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Holy ****, I don't even know what to say here..
http://www.ebay.com/itm/162081457388
Old 05-27-2016, 09:43 AM
  #223
anesthes's Avatar
Intake needs to be welded, milled, and re-ported.
-- Joe
Old 05-27-2016, 10:07 AM
  #224
Tibo's Avatar
Car: 1991 Z28 Vert
and after the welding and milling and price paid for this intake you could have bought one in decent shape.
Old 05-27-2016, 11:39 AM
  #225
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Looks to me it also would need new fuel rails. Does this guy have no friends and own no computer? How do you even get to this point?
Old 10-17-2016, 01:05 AM
  #226
B4Ctom1's Avatar
Car: 1992 B4C 1LE
Another http://www.ebay.com/itm/322295054288
Old 10-17-2016, 05:47 AM
  #227
anesthes's Avatar
That went kinda high. Maybe I should sell mine.
-- Joe
Old 05-28-2018, 11:25 AM
  #228
B4Ctom1's Avatar
Car: 1992 B4C 1LE
https://www.thirdgen.org/forums/engi...s-miniram.html
Old 10-22-2019, 08:35 PM
  #229
B4Ctom1's Avatar
Car: 1992 B4C 1LE
https://www.ebay.com/itm/293290283840
Old 10-22-2019, 09:58 PM
  #230
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
cute little runners for the small block...
MantyZ28
16
12-21-2015 11:02 AM
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
Firechicken86
08-12-2015 10:07 PM
mcgarnicle
08-12-2015 04:58 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: TPIS Minirams are finally selling (cheap?) on ebay
