TPIS Minirams are finally selling (cheap?) on ebay
#205
1 Post
Car: 1992 B4C 1LE
Re: TPIS Minirams are finally selling (cheap?) on ebay
Accel Super Ram new old stock
http://www.ebay.com/itm/371324585808
#206
#207
1 Post
Car: 1992 B4C 1LE
Best price in years $700 buy it now with a throttle body and rails. Doesn't say injectors, but I see them in the pics.
http://www.ebay.com/itm/191581819664
1205 size gaskets
be gone by morning?
1205 size gaskets
be gone by morning?
#208
1 Post
Car: 1992 B4C 1LE
This miniram with everything but the TB and having the 1206 gasket ports and at only $650 won't last the day http://www.ebay.com/itm/252041582689
#210
1 Post
Car: 1992 B4C 1LE
#211
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
They are a bitch to tune. Plenum is too small, fuel distribution sucks, and the 1205 version doesn't have enough casting to cover 1206 heads.
-- Joe
#212
1 Post
Car: 1992 B4C 1LE
The Holley Stealth ram or a single plane are probably still the ideal setup for our rides?
#213
The HSR is a compromise. You get a good plenum, but tight angles on the airflow. I have an HSR on my turbo car but I figure whatever loss I get due to the intake I can make up with boost.
The Miniram is impossible to tune. You always get lean or rich cyls. People don't realize that the LT1 had a sequential ECM with a per-cylinder fuel trim. You can't do that with an 80's delco ECM.
-- Joe
#214
1 Post
Car: 1992 B4C 1LE
How about tuning with something like a Bigstuff 3?
#215
1 Post
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
The TPIS Mini Ram has fuel reversion problems.It sucks fuel up into the back of the plenum.So your rear cylinders will always run rich.and there's nothing you can do about it no matter how much tuning you do.Plus you trade a boat load of torque for horsepower.
#216
1 Post
Car: 1992 B4C 1LE
Thanks, good to know. From both of you.
#217
I wonder if the 24x system would be a viable solution to address that.
#218
The only stock stuff I have experience with is the older DELCO (thirdgen, C4) and LT1 stuff. I've not touched any of the LSx stuff. And all I use is aftermarket now.
Cylinder injector trim is still a band aid for a defective manifold design.
-- Joe
#222
1 Post
Car: 1992 B4C 1LE
#223
-- Joe
#225
1 Post
Car: 1992 B4C 1LE
Looks to me it also would need new fuel rails. Does this guy have no friends and own no computer? How do you even get to this point?
#227
-- Joe
#228
1 Post
Car: 1992 B4C 1LE
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
Firechicken86
08-12-2015 10:07 PM
Sanjay
08-12-2015 03:41 PM
