door lock black cover/coating-85 camaro
Car: 85 Camaro /65 Lemans
Engine: 305 vin H / 396-375 hp (Real)
Transmission: 700R4 / 4sp
Axle/Gears: 3.08 posi / 4.88 posi
Hi all,
This may be a dumb ques, but I'll try anyway. One of my door locks has a big chip on what looks to be a rubber/plastic cover on it. Can you buy these "covers" anywhere? or do you need to replace the lockset which would be a waste of money I don't have
thank you
tom
thank you
tom
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
Re: door lock black cover/coating-85 camaro
You can buy replacement lock parts . . I've found them on eBay . . . a bit tricky to install.
You have to remove the lock cylinder from the door, then carefully pry the 4 prongs that are pressed to the lock body, remove the "ring" BUT don't let the spring loaded inside parts pop out! . . . then put ring on and press the 4 tabs back down . .
Thanks for the info and picture Polo z03,
I was just asking about the black plastic coating (round with a hole in the center - bottom center of your picture ) where a piece of mine is broke off. For now I just painted the area black as I don't think I could by just that piece which is likely glued on. A better fix would be to apply and sand some epoxy putty to the missing area and then paint it black.
Have a great day and thanks for helping.
tom
tom
