Question on bleeding front brakes....
Old 08-26-2009, 02:20 PM
dp149's Avatar
Hey Everyone...I just picked up a project car (1988 GTA, 4 wheel disc, 5.7, auto) All stock but sitting in a field for 10 years!
I will probably have a ton of questions but here is my first....The brake pedal goes to the floor and needless to say little to no brakes. I put the car on jacks, and cracked all the bleeder screws. I was able to bleed the back brakes without issue, but the fronts (both sides) when I completely remove the bleeder screw, no fluid comes out. The Master Cylinder is full. If i pump the brakes, nothing comes out. WHere is the first place to look? I am guessing master cylinder is bad or proportioning valve? any help would be appreciated. BTW car has 60K original miles, digital dash, etc. loaded so I want to put it back to new...thanks...
Old 08-26-2009, 05:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Question on bleeding front brakes....
its possible, and quite likely, that the issue is the front rubber flex lines. They tend to rot and deteriorate on the inside and stop fluid from traveling through them. See if you can get them off the hardlines and see if you have fluid at the hardlines.
Frozer!!!
01-19-2024 04:55 PM
69 Six Pack
10-05-2015 07:51 PM
backtothe80s
09-05-2015 12:39 AM
redmaroz
08-16-2015 11:40 PM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Quick Reply: Question on bleeding front brakes....
