Cheap Proportioning Valve Upgrade
Old 05-26-2012, 01:58 PM
  #101
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: Cheap Proportioning Valve Upgrade
Originally Posted by 83C_CamAroZ28
I have a 83 camaro but mine doesn't have the chamber there it has it on the end pointing to the driver side. I'll try to post a picture later on. And I can't give results just yet because I'm replacing my lifters...:/..
That's gonna be one I've never seen before...
Old 05-29-2012, 02:01 PM
  #102
Z28Smitty's Avatar
Car: 1992 Camaro Z28 Z03 Vert
Engine: 5.7L Vortec TPI
Axle/Gears: 3.23 Posi
Originally Posted by norcalz28
How involved is this swap? Can it be done in the car or does the valve have to come out?
Will
The spring install takes less than 5 minutes and really makes a big differance in rear braking effectiveness. I just changed out the spring yesterday when i completed my drum to disc swap and the improvement is outstanding. I don't think my rear drums were doing anything to stop the car. Now it stops on a dime.
I have 4 springs left from my package of 5. If anyone wants one send me a PM. No charge. Just send a self addressed padded enevlope with return postage and I'll mail you one.
Old 05-29-2012, 07:32 PM
  #103
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
which spring did you use? the 1NCF2 or 1NCR5
Old 05-29-2012, 08:15 PM
  #104
patricklav's Avatar
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
PM sent
Old 05-29-2012, 10:58 PM
  #105
Z28Smitty's Avatar
I used the 1NCR5 spring.
Old 06-12-2012, 08:29 AM
  #106
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Thanks for the pictures,
I'm getting mine from Art once its done I'll explain to my wife how to help me bleed the brakes without bitching.
( basically push the pedal but don't say **** except down -up)
Old 07-01-2012, 06:21 PM
  #107
Method_z28's Avatar
Car: 92 camaro z28
Anybody have one for sale?
Old 07-12-2012, 05:50 PM
  #108
blunierdr's Avatar
Car: 87 Trans Am GTA
Engine: Vortec Stealth Rammed L98
I ordered both spring rates and I am going to do some testing with them. I will post my experiences here after I am done. I think it's about time I put those rear disks to work for once in their miserable lives.
Old 07-12-2012, 10:11 PM
  #109
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
PM Sent.
Old 07-12-2012, 10:28 PM
  #110
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Just got my pack from Grainger, going to try it out tomorrow.
Anyone had any problems at the drag strip with this upgrade?
Edit, Holy cow, what a difference!
Old 07-14-2012, 10:43 PM
  #111
blunierdr's Avatar
Alright guys, I got the springs from Grainger this week and tonight I installed the stiffer of the two springs (1NCF2) on my GTA.
Just a heads up to anyone doing this mod, after I installed the stiffer spring, I had to bleed air out of both the rear AND front lines. There was actually more air in the front lines that there was in the rear. At any rate, after bleeding the brakes thoroughly, the pedal feels good and firm.
My main concern when installing the stiff spring was that I would have TO much pressure to my rear brakes, causing them to lock up before the fronts under heavy braking, since most of the weight is shifted over the front tires under fast deceleration. When I did take the car out on the road, I did a few hard, straight stops. I was very pleased to be able to tell that there was a noticeable decrease in braking distances. When pushed to their limits, the rear tires did start to talk back, around the same time that the fronts started to chirp. Ideally, I would like to see the rears start to lose traction a little bit later than they do in the current setup, but after doing a more thorough test of the brakes, (more moderate to very heavy braking, along with moderate to heavy braking during corners) I found that the rears don't want to lock up to abruptly, and even while braking heavily in the middle of a corner, the car seems to handle well. The extra braking force to the rear of the car does make for a slight amount of oversteer during braking, but I actually like it. The car used to push really bad when braking during a corner, not what I wanted at all. Overall I am very impressed with this mod!
I have stock calipers with cross drilled and slotted rotors and ceramic pads, so my brakes aren't anything too extravagant, but feel much better than the stock brakes to begin with. The extra braking force to the rear wheels definitely lets the stock braking system work at its full potential.
Not sure if anyone is curious or not, but I included a picture comparing the three springs side by side.
(from left to right: stock spring, 19lb spring (1NCR5), 22lb spring (1NCF2))
Old 07-14-2012, 11:05 PM
  #112
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
No, no problems for me at the drag strip and anywhere else for that matter. Still working good with no problems encountered.
Old 07-14-2012, 11:22 PM
  #113
Arvizu9618's Avatar
Old 07-14-2012, 11:25 PM
  #114
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Originally Posted by Arvizu9618
Brakes aren't spongy any more, feels like pressure is building, brake light is now off...anything else?
Which spring did u use?...
Old 07-14-2012, 11:43 PM
  #115
Arvizu9618's Avatar
1NCF2
Old 07-17-2012, 07:05 AM
  #116
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Just by way of reference for you all, McMaster Carr springs are as follows:
http://www.mcmaster.com/#compression-springs/=ifzr6a
Lg. Spring
OD Wire
Dia. Compressed
Lg. Load,
lbs. Rate,
lbs./inch Pkg.
of 5
1.500" 0.48" 0.063" 0.694" 22.94 37.00 9434K121
$5.11
Lg. Spring
OD Wire
Dia. Compressed
Lg. Load,
lbs. Rate,
lbs./inch Pkg.
of 5
1.500" 0.48" 0.063" 0.694" 19.93 32.15 9435K123
$6.31
Old 07-26-2012, 06:13 PM
  #117
blakecharles's Avatar
who has a 22in/lbs spring that will ship to 94546??? Anyone running LS1 rears with this?
Old 07-28-2012, 08:17 PM
  #118
BOTTLEDZ28's Avatar
Transmission: A4
Im also looking for the higher rate spring. Please PM me with a price if anyone has an extra one. Thank you.
nevermind. I ordered a pack of them from Grainger. I got the 1NCF2 spring so if someone needs one then let me know. They should be here around the 31st.
Old 07-30-2012, 05:52 PM
  #119
Scott85's Avatar
Car: 91 B4C
Transmission: auto
I picked up the lower rate spring from Mcmaster Carr , 9435K123. If anyone needs one, PM me.
Old 08-01-2012, 12:50 PM
  #120
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I got the 1NCF2 spring if anyone need one $5.00 plus shipping
Old 08-01-2012, 01:41 PM
  #121
55ChevyMan's Avatar
I started changing the spring it came out easy but the new spring does want to go in I will have to remove the AC compressor 94 Corvette Lt1 with the vette AC
Old 08-02-2012, 10:11 PM
  #122
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
picked up the spings today and intalled it but still need to bleed brakes
Old 08-02-2012, 10:38 PM
  #123
55ChevyMan's Avatar
got it in I plan on using a Phoenix Reverse bleeding System when bleeding the brakes
Old 09-16-2012, 07:08 PM
  #124
HottestZ28's Avatar
Anyone still have single springs for sale? Pm me
Old 09-16-2012, 09:44 PM
  #125
55ChevyMan's Avatar
I GOT 2 LEFT 5 dollars plus shipping
Old 09-17-2012, 08:36 PM
  #126
84z4me's Avatar
Car: 84 z
Engine: 383
Transmission: 700r-4
Axle/Gears: 2.77 9 bolt
Originally Posted by 55ChevyMan
I GOT 2 LEFT 4 dollars plus shipping
Pm sent.
Old 09-17-2012, 10:21 PM
  #127
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Will this spring work/help or remove the need to change the PV when swaping from rear drum to LS1? Or would I still need to get a new PV?
Old 09-21-2012, 10:50 PM
  #128
x11nt4's Avatar
I can confirm that the Grainger 1NCF2 is in fact a direct swap-in replacement for the 82-84 cast iron CV's. There is a noticeable stiffness difference between the stock disk/drum spring and this new one. I'm guessing the old feel's about 15/lb but i have no way to confirm an exact lb number.
Old 09-22-2012, 10:51 AM
  #129
55ChevyMan's Avatar
I change mine and it big difference much better an improvement now my rear disc work
Old 09-24-2012, 10:30 PM
  #130
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 5 speed manuel
Axle/Gears: 3.08
Does anyone have any of these springs left? I would like to buy one.
Old 09-25-2012, 04:36 PM
  #131
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Nevermind just ordered a pack of the 1NCF5.
Old 09-25-2012, 04:44 PM
  #132
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Sorry meant 1NCR5
Old 09-27-2012, 03:54 PM
  #133
HottestZ28's Avatar
Still looking for a single spring
Old 09-28-2012, 10:12 AM
  #134
55ChevyMan's Avatar
do you still want that spring ?
Old 09-28-2012, 11:42 AM
  #135
HottestZ28's Avatar
^^^ yes still in search
Old 09-28-2012, 01:47 PM
  #136
55ChevyMan's Avatar
send me your address I don't shipping would cost more then buck are two
Old 09-29-2012, 07:54 AM
  #137
HottestZ28's Avatar
Email sent
Old 10-01-2012, 02:55 PM
  #138
55ChevyMan's Avatar
my pay pal address is brioneschevybelair@yahoo.com to pay for the spring
thankyou
Old 10-02-2012, 07:24 AM
  #139
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
so i happend across this thread today and searched the basement for springs grandpa did lot of pinball machine repair in his day would you believe he had a sorted cabniet of springs by length and strength rating i tested 20,25,28,33,38lb .
all i can say is "thanks grandpa" and here i was about to toss all this stuff
mind you its raining so figured perfect time to test ; 38lb locks the rears every single time you jam on the brakes kicks out bad too so i skipped the 36 and 34 rated; 32 the rears lock almost instantly after the fronts do good but could get hair in a panic stop ; 28 seemed to be the the best as the rears have great stopping power but lock only after the fronts do but not every time very predictible brakeing i couldnt find a 30lb rating in this length
20 no differant then stock prop 25 seemed much better but still couldnt lock the rears even in poring rain but you could feel the rear brakeing effect i may swap back to this
i really shouldnt have stayed up all night doing this got to work now in an hour lol
my brake setup is Corvette c4 12 inch up front and stock 92 fbody pbr rear basicly the 1le setup my front rotors keep getting heat fractures from doing my guess 90 % of the stopping power car im hoping the testing i just did helps somebody
Old 10-14-2012, 03:40 PM
  #140
camarosobbing's Avatar
Car: 86 camaro z-28 t-tops
Engine: 387
Transmission: turbo 350 reverse v body 8 inch tsi
Axle/Gears: ford 9 inch 4.30 gear
Anyone have a spring for sale ?
Old 10-14-2012, 06:53 PM
  #141
55ChevyMan's Avatar
I got some 5 bucks shipped
Old 10-15-2012, 07:29 AM
  #142
Engine: 387
Paypal is sent to you 55chevyman, Shoot me a message once you ship it.
Thanks for the help!
jason
Old 10-15-2012, 10:09 AM
  #143
55ChevyMan's Avatar
send me a address to send to and my paypal is brioneschevybelair@yahoo.com I See you paid paypal now send me your Address to send you the spring thank you
Old 10-15-2012, 10:21 AM
  #144
Engine: 387
Just emailed you the info thanks
Old 10-16-2012, 05:46 PM
  #145
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
just came across this thread today. ran out to buy some springs after reading it. installation was super easy (besides trying to get the cap back on) and straightforward. now all i need is to bleed the brakes and i can enjoy awesome brakes! thanks guys!
Old 10-23-2012, 02:48 AM
  #146
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Does anyone know if theres a diff for drum prop valve?? I swappped to disx reara but the donor car had a crapped out valve so i havnt had a chance to fix it really. Could this be a small help or should i find a 4disc valve and swap the internal spring for maximized brake performance?? I just need this for a tiny bit as a yeae from now ill be doing a big brake upgrade but it wont hurt getting used to beter brake force for when i get big brakes.
Old 10-24-2012, 05:07 PM
  #147
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
I had a drum proportional valve still in when I did a rear disc brake swap and brakes barely would stop then I put a grainger 1ncr5 spring and now it stops quick. This simple upgrade took like 2 minutes to do and made all the difference in the world.
Old 10-24-2012, 05:13 PM
  #148
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Yes there is a difference in the proportional valves in the drum and disc brake cars but the spring gives enough pressure to the rear brakes.
Old 10-26-2012, 11:34 AM
  #149
pg29's Avatar
Car: 88 GTA
Does anyone have an extra grainger 1NCF2 22 Lb spring that they'd be willing to sell to me? I'm located in Canada. Pm me and let me know. Thanks.
Old 10-26-2012, 09:19 PM
  #150
55ChevyMan's Avatar
I have some but if you can get from grainger it cheaper what sucks is shipping
Quick Reply: Cheap Proportioning Valve Upgrade
