Brake pad problem
Old 10-01-2011, 01:31 AM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
Brake pad problem
When i was installing my out board brack pads the pad wont stay sitting in the caliper. Im using wagner thermoquiet pads. Do you just do a balancing act and sit it against the rotor to keep it from moving? Most cars I change have clips of some sort holding it on. It fits in the slot on the rotors fine, just loose enough to fall out.
Old 10-01-2011, 08:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Brake pad problem
Fronts with cast iron calipers? If so there should be tabs on the pad that retain it. The two small tabs then get bent toward the caliper to prevent the pad from clunking when the brakes are applied.
RBob.
Old 11-12-2011, 05:20 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
how do you like these brake pads? are they quiet? im gonna be replacing pads here soon( in the spring) and im going to get these pads.
Old 11-12-2011, 11:57 PM
Car: 1984 Trans Am
Axle/Gears: Stock
They are actually pretty decent pads. Nice and quiet and good grip. Id recommend them if you want a good daily pad.
Old 11-13-2011, 08:39 AM
Engine: L31 350
That's great, thank you. Are you still using the stock calipers aswell and did you finly get the brake pads to fit. I'm looking forward to doing these. Now if only the sold these in the brake shoes for my drums lol
Old 11-13-2011, 01:56 PM
Car: 1984 Trans Am
Axle/Gears: Stock
Ya I have stock calipers but there reman because both of mine were starting to stick shut. One I got the tabs bent right the pads fit just fine, they were just really thick brackets that I wasnt use to.
Vintageracer
01-10-2020 05:33 PM
Eric-86sc
04-03-2016 03:52 PM
articwhiteZ
Aftermarket Vendor Review
08-18-2015 07:26 AM
kyleb24
08-15-2015 08:24 AM
Zachattack0925
08-12-2015 09:52 PM
Quick Reply: Brake pad problem
