1LE brakes
Old Nov 14, 2011 | 11:06 PM
ynk1121's Avatar
Car: 90 IROC, 95 Vette
1LE brakes
Will these fit under 15" 88-90 Iroc rims?
I did a search but not too many pictures turned up of the process. Does anyone have a step by step idiots guide to doing the swap?
Old Nov 15, 2011 | 06:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1LE brakes
Check the sticky at the top of the page.
Here are a couple of links that may be useful:
http://web.archive.org/web/200605221.../1LEbrake.html
http://lukeskaff.com/?page_id=396
JamesC
Old Nov 15, 2011 | 06:49 PM
ynk1121's Avatar
Re: 1LE brakes
JamesC
I read the sticky but all I got is "1LEs will fit some 15" wheels". No mention of a definite fitment on 15" 88-90 irocs that I saw.
Thanks. So basically all there is to it is making two holes larger, tapping them, and cutting off the piece the old calipers attached to on the spindle/knuckle? That doesn't seem too difficult.
Old Nov 15, 2011 | 07:05 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: 1LE brakes
Hey James, cool on the second link. Very informative.
Old Nov 15, 2011 | 08:38 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Re: 1LE brakes
Q: Will the LS1 setup clear my stock 15 or 16 inch wheels?
A: This setup will not clear any 15 inch rims that came stock on thirdgens. Here are the rims that will work:
- Early model & Late model IROC 16 inch rims
- Some GTA and Firebird rims work some don't you will need to research that on thirdgen.org
Some firebird/GTA rims need shims to space out the wheel, this can be done with GM part number 14091902 (.030 inches thick).
Old Nov 15, 2011 | 08:47 PM
JamesC's Avatar
Re: 1LE brakes
Sorry, I should have added this to the two links above:
JamesC
Old Nov 16, 2011 | 12:32 AM
ynk1121's Avatar
Re: 1LE brakes
Thanks but I'm not looking to do a LS1 swap. I'm looking to do the 1LE which is smaller. The flynbye site says it "Fits most 15" wheels" but also does not mention which it will or will not.
Old Nov 16, 2011 | 07:48 AM
JamesC's Avatar
Re: 1LE brakes
Check what Pat Hall says in post #4 of the following link:
https://www.thirdgen.org/forums/tran...oc-wheels.html
JamesC
Old Nov 16, 2011 | 04:25 PM
ynk1121's Avatar
Re: 1LE brakes
JamesC
Great, so it should fit. Thank you.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
