88 Iroc 350TPI 4wheel disc TTop
Car: 86 Iroc
Engine: 420HP/440FT-LB SB355
Axle/Gears: 10 Bolt 3.73
Looking to unload the car or end up parting it out if I can't sell it as a whole so here goes...
The car is currently located outside of Allentown in the small town of Pennsburg.
GM 350 HO with Vortec Heads, SLP Runners, stock injectors/TB/Plenum...has about 100,000 since I put the motor in, mostly highway miles from commuting to college and work in the summer. 700R4 trans with shift kit, rebuilt two years ago, and just replace the front seal in the spring has about 30k on since rebuild. Alum drive shaft, rebuilt 3.42 10 bolt rear with Eaton carrier and 12" disc brake swap from the LS1 style rear brakes. 3 5/8 Eldelbrock shorty headers with 3" flowmaster cat back exhaust minus the cat. Has after market LCA's, pan hard rod, urethane bushings, hotchkis springs, billstein struts, and sphon SFC's that are NOT installed on the car. The car still runs strong, runs rich/rough at idle when cold as its not properly tuned, but runs fine after it warms up.
The body needs lots of work, rust starting on drivers door, both pass/driver side quarters, as well as aft of the TTops and on the deck lid. SS style fiberglass hood that needs a minor repair. Make no mistake the body needs TLC and paint. The car was hit/repainted by a previous owner, so the drivers side isn't as bad as the pass. The ttops do leak, and there is a fair amount of rust under where the TTops are.
The interior has 93+ carmaro two tone grey seats, driver side has the usual rip/tear, while the others are in good shape with no rips. Usual wear beyond the seats, has a new headliner, and sun visors not installed due to leaky tops. Usual wear and tear remains, needs a new shifter plate. Has panasonic head unit, with pioneer 6x9's.
3500 obo
I will have some pictures posted in the next day or two. I have most receipts for the parts installed on the car but not all. It needs a lot of TLC with the body, drive train wise I have kept up with all of the maintenance on and is drive able, however not emissions legal in PA. I'm leaving for flight school in Feb, and will not be able to continue it as the project I had started out on. If I don't sell it I will end up parting it out and keeping the motor/trans/rear for future use.
I have extra parts as well, i have 3 wheels that are stripped/polished (the last wheel just needs the finishing touchs put on it). The SFC's, B&M tranny cooler stock intake/runners, software/hardware for PROM burning, ALDL cable, and a few other little things stashed away in my storage that are slipping my mind at the moment.
3500 obo
Car: 86 Iroc
Re: 88 Iroc 350TPI 4wheel disc TTop
Waiting to get them from my friend where i have the car stored at...should be today/tomorrow
Car: 86 Iroc
update i do have pictures send me a private message with your email and I will fwd them easier than posting them since there are a few.
Car: 86 Iroc
have someone looking at the camaro this weekend, if it doesn't sell id be interested in selling it. I'll let ya know.
ambainb
04-25-2016 09:21 PM
sailtexas186548
01-19-2016 12:21 PM
1989formula5.7l
08-15-2015 11:35 AM
mustangman65_79
08-11-2015 03:17 PM
