i need vacuum hose help.. Rochester....
Old 08-02-2002, 09:57 AM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
ok... i've got a 78 qjet.. the thing has more plugs in it that anything....(rubber hoses with screws in the end)
ok.. i have my vac advanced hooked up to the vacuum port on the pass side front....... and the PCV.. in the front.. thats it ...
i have a plug on the front of the carb driverside on the baseplate.... what should go there?
at the top of the carb on the back between the a/v flaps theres another one ..blocked off... and just below that on the back baseplate theres another blocked off......................
what are these connections for....??
i get about 9 miles a gallon..
Rob
Old 08-07-2002, 03:09 PM
nosibear's Avatar
The port on the drivers front is probably for vac. operated choke or cold start canister. On the backside bottom should be port for vac. modulator on tranny.
Old 08-07-2002, 03:11 PM
nosibear's Avatar
And I think the one on the backside at the top went to air valve in the stock air cleaner.
Old 08-07-2002, 05:48 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The one on the back topside by the air valve went to the hot air choke (source for filtered air).
Old 08-07-2002, 05:58 PM
Car: 1983 Z28 Clone
Transmission: TH350
thanx guys
Pac J
05-17-2020 10:44 AM
sheachopper
07-31-2019 11:27 AM
FormulasOnly
07-23-2018 08:47 AM
HoosierinWA
10-07-2015 10:15 AM
dusterbd
09-29-2015 08:40 AM
Quick Reply: i need vacuum hose help.. Rochester....
