Holley Base Plate missing slot
Old 08-13-2012, 11:41 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
I cracked the base plate on my Holley 80457 (4160) carb and bought a used one on ebay. The one from ebay is missing transfer slots in the primary bores. (see pictures). Is this going to be a problem.
Everything else about the plates is identical including the part numbers stamped on them.
Attached Thumbnails Holley Base Plate missing slot-baseplate-1.jpg   Holley Base Plate missing slot-baseplate-2.jpg
Old 08-15-2012, 06:28 PM
Received 1,672 Likes on 1,269 Posts
Re: Holley Base Plate missing slot
Yes that will be a problem. It has no chance whatsoever of running right without them.
If the slots are totally absent, then you just discovered why it was on ebay instead of on a car.
Old 08-15-2012, 07:15 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Can you use a very fine cutting wheel to cut them yourself?
Old 08-15-2012, 09:42 PM
oamhmad's Avatar
Car: 84 Trans AM
Funny thing is this is a used part and shows evidence of having quite a few miles on it. There is varnish and residue in the bores.
I'm just going to return it I guess.
Old 08-16-2012, 11:49 AM
Damon's Avatar
Good choice. That just ain't going to work.
I'm trying to think of an application that wouldn't need transfer slots like boats or agricultural applications..... and I can't think of one. I think that's just a actory defect. In any case it's not going to work in a car.
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
9192camaro
16
02-03-2019 12:21 AM
mhatfield 14
10-24-2015 07:48 AM
355tpipickup
Alternative Port EFI Intakes
08-22-2015 06:06 PM
Quick Reply: Holley Base Plate missing slot
