1985 LG4 Rough Idle Occasional Stalling
Old 05-24-2015, 09:53 PM
Firm's Avatar
Car: 84 Camaro 2.8L, 85 T/A 305 LG4
I've got a bone stock 85 Trans Am with the LG4. Low mileage car. I've owned it for a few months now and it's been running pretty good. Always starts easy, strong acceleration and cruises very smooth. The only issue I've been having recently is a rough idle when warm which will occasionally stall out.
Basically, I'll start the car and the choke will keep the idle high until it warms up - no issues there. Once it is warm it runs perfectly until i get to a stop light, with the car in gear (automatic) and my foot on the brake it idles right around 500rpm, but it's often pretty rough. Typically it doesn't stall, but yesterday it did stall twice in about 2-hours worth of driving.
Today I poked around looking for vacuum leaks but I didn't find anything obvious, I didn't have any carb cleaner to spray, so that'll be one of the next things I try. Are there "common" places to find vacuum leaks on these cars?
The carb itself looks like it's been replaced in the not so distant past, but maybe it needs to be cleaned? How would i know?
Anything else I should be checking with these symptoms?
Old 05-25-2015, 02:11 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Re: 1985 LG4 Rough Idle Occasional Stalling
Replace all the vacuum lines anyway. The idle in drive should be around 600.
Also, check your timing and do a tune up. Plugs, plug-wires, cap, rotor.
The last time mine started stumbling a while back and it was a a plug wire shorting to my manifolds.
The time before that I didn't get a a plug wire seated properly and my number 6 cylinder wasn't firing. The car would run fine under throttle but would stutter, have a really low idle and want to die when stopped and in gear.
So, start with the tune up and see if that helps any. Once we know all the parts are good, we can check other things.
Old 05-25-2015, 05:02 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
If a simple tune up doesn't fix it, I'd inspect the EGR system, the valve could be stuck open causing a lean condition after the engine is warmed up.
Old 05-26-2015, 08:40 AM
Firm's Avatar
Good suggestions. I've ordered everything for a tune up, so I'll start there - it can't hurt anyway. I am also going to keep looking for vacuum leaks, this time using some carb cleaner. Hopefully I'll be able to get to it this weekend and I'll report back.
Old 10-14-2015, 11:42 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Did you ever find a solution for your low idle problem. My 1985 Trans Am LG4 just started doing the same thing. I'll be looking at the PCV hose and valve, as well as the fuel filter. Would be great to find out what yours turned out to be.
jklein337
09-19-2018 06:23 PM
Bryan F
08-18-2015 02:28 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: 1985 LG4 Rough Idle Occasional Stalling
