How do I check the float level?
Old 01-02-2001, 08:45 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Guy's can I check it with out takeing the carb apart? If I have to take the carb apart do I have to reset anything (tps mixture control or anything else)? what should the float be set at? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old 01-03-2001, 09:10 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah, you have to take the airhorn off to check the float level. After you get it back together you definitely want to reset the TPS. The MCS lean stop won't be affected, but the rich stop (if you have an airhorn mounted stop screw) might be slightly changed, but i don't think it would move enough to even matter. Same withe the IAB, although it wouldn't hurt to reset it anyway, esp. if it is set right now and you move the float level.
As for the spec on the float, it depends on the particular carb #. Rebuild kits generally come with a sheet with specs for everything they service. I don't think my haynes has any such specs listed. If someone comes in here and says something on the order of 'all qjets are set at xxx' they are lying. Like i said, rebuild kits come with a sheet full of numbvers for EVERY different carb #, and they are all different, and correct float height is a very big deal.
...ed
...ed
Old 01-03-2001, 04:49 PM
BLACK Z's Avatar
Car: 86 Z28
Ed could you please explain to me in detail, how to check the float, adjust the float, how to adjust the tps, where it should be set at,how to adjust the ab, and anything else, most likely it will be adjusted using a scanner, and please go in to detail, thank you so much.
Old 01-09-2001, 05:56 PM
BLACK Z's Avatar
Car: 86 Z28
Old 01-21-2001, 02:29 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Old 01-22-2001, 08:58 AM
Ed Maher's Avatar
Car: 04 GTO
Ack, i'll be typing all morning...
Here's a synopsys, if you need more detail you'll have to get a manual. Hell, getting a manual would be an OK idea anyway.
Check/set float- take off airhorn. Hold the front of the float down to seat the needle, get your measuring implement (ruler) and measure the height of the back of the float. To adjust you bend the flat arm.
TPS- First you need to remove the plug covering it. To the right of the acc. pump arm you'll see the plug. Very carefully drill a small hole in the plug, then screw a small self-tapping screw into the hole. Pull out with pliers.
To adjust you need a special tool, you can get it at www.thexton.com , i don't rememeber the PN offhand. It comes in a carb adjusting kit.
You check the voltage by measuring between the middle and bottom wires ceoming from the front DS of the carb. With the throttle closed (and not on fast idle cam) you should get 0.5 V, and it should smoothly increase through it's range of motin to somewhere past 4V at WOT.
To set the IAB is a little trickier. There's a special tool to rough it in if you've removed it, but if it's still set as stock then it's close. Basically you adjust this with the car in gear and a dwell-meter hooked up to the green connector found by the heater blower motor. Try to get 30' dwell.
You screw the IAB down to richen things, and VV.
hope that helps...ed
skeltor
02-02-2016 10:37 AM
pjsparts
09-17-2015 01:28 PM
Nick McCardle
09-10-2015 08:36 PM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: How do I check the float level?
