Want to buy 87-92 Convertible Camaro Fenders
I need both the drivers side & passenger side front fenders for a 1987-1992 Third Generation Convertible Camaro.
They are physically different from other 82-92 3rd Generation Camaro Fenders.
I do not want aftermarket, reproduction or repop fenders...
Please no rust or major damage.
P/M me IF you have a OEM GM pair.
Unless otherwise noted, IF you are reading this I am STILL looking.
thanks in advance.
thanks in advance.
Car: 1990 Iroc Z Red Vert
Axle/Gears: Stock
Re: Want to buy 87-92 Convertible Camaro Fenders
Hardtop and convertible fenders are the same. The convertible fenders have about 4 inches cut off the bottom because of the frame and outer rocker reinforcement done to the car by the ASC conversion. There is a custom lower mounting bracket used on the bottom of the fender to mount to the car for the convertible conversion.. That bracket is riveted to the lower fender then bolted to the car body. Look at the pair of original vert fenders that you have and you will see the lower fender bracket. I have taken a pair of fenders and cut off the lower area and mounted the brackets to the fenders. Not that hard if you use the old fenders as a pattern. The 85-90 fenders are different than the 91-92 fenders only with the mounting holes for the 85-90 and the mounting slots for the 91-92 where the front ground affects mount to the lower part of the fender. I hope that this helps you. Botch1
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
1992 Trans Am
08-09-2015 04:32 PM
